Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dishwasher f1 problem
My dishwasher drawers are in an f1 fault mode. The lights keep flashing and the machines keep beeping. When I attempt to turn them off, they just start up again with the same pattern. The top drawer loaded (although not overloaded) and the bottom is empty. please help!
  • 5 more comments
  • Anonymous Sep 01, 2008
    Both drawers are in an F1 error code and just keep beeping and flashing - The only way to stop this is to unplug it. Unplugging it has cleared the problem in the past, but this time is not clearing the error. I took everything apart in the tub thinking that something was keeping the gears from working - all was okay. Not sure what is going on!
  • Anonymous Feb 23, 2009
    i have the same problem how do u fix it
  • fursefamily Feb 27, 2009
    f1 blinking and beeping book says flooded?
  • sharonj728 Mar 02, 2009
    I have the same problem with the F1 (flood) light being on.
    When the machine was on it would trip the plug.
    I took the entire machine apart and found the computer sensor is burned up. Looks like it had gotten wet.
    I must replace it.
    I have the technician coming to my home on March 6th.
  • Anonymous Mar 13, 2009
    I have the same problem. Apparently the F1 means the flooding switch has been activated. There is however no flooding anywhere. How do I reset the switch?
  • jetl Mar 24, 2009
    Both drawers appeares F1 problem, I tried to turn off water & power line, but I turn it on, problem still the same
  • sraybon1 Apr 08, 2009
    Same problem of F1 code error with no floodong or moisture at all. Is the company doing anything about this common problem ??
Thanks for the follow up. I ended up calling a service representative in my area to complete the repair.
Posted on Aug 18, 2008
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
We have the Q 2 drawer dishwasher stopped working.
the f1 is the flood sensor....a leak has accured....either a dish to larger or lid motor has failed. will need to remove bottom drawer and soak up water and then let air dry for a day or two....turn off the breaker this will keep it from beeping and running the pumps....after drying unit will run, but need to watch the dishes you put in drawers.
Jun 30, 2009 | Fisher and Paykel DD605HSS 23 in. Built-in...
I have a Fisher Paykel dishwasher that is beeping
you have to remove the bottom drawer ......
f1 fault is a fload fault
e-mail me and ill give you my cell number
cause im factory cert. for this company
Jun 23, 2009 | Dishwashers
Cant turn off the dishwasher
Babas, the F1 fault code for most FP dishwasher models means that there is a leak. It can be one or both drawers. Regardless of which is leaking, your fault code is telling you that the base pan has water inside. You will probably need to call for factory service to repair.
Mar 31, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
589 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
