PRINTER WILL ONLY PRINT 1 COPY - Office Equipment & Supplies
  • Tami Drog Mar 29, 2009
    i just want to click print 10 copies (in Word, ie) and have it do it. Like it used to!
  • 1,800 Answers
Hi i will help u and u help me by rating this as fixya okay there u go:
set it to make however of copies u want its in the spool service
manager
or u can find it by using ctrl+p if u r using some kinda software
Internet Explorer,Word, Exel
Posted on Aug 18, 2008
When I print 1 copy from my laptop, it will not stop printing many copies and I tried to copy a photo and there are horizontal lines on the copy. Jacques
The numbers of copies your laptop print out is set in your printer software.
You did probably forget to change the numbers to 1 (one copy).
If you use normal print paper for photos, it will almost always make horizontal lines.
Use photo print paper instead, then it won't happen.
It could also be that your print cartridges need a nozzle cleaning.
Normally your printer software has a mode to this.
Hope this will help you
Regards
Aug 29, 2011 | Kodak Cameras
My printer cannot print anymore, what i can do
Are you able to make copy from printer or print test page ?
If you are not able to make copy from printer or print self test page
Check if the cartridges are not empty.
If they have ink, follow the steps below
1. Disconnect the power cable from back of printer
2. Wait for 10 seconds and re-connect the power cord to printer.
Or if the copy works fine from printer and you are not able to print from PC only, follow the solution below.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 28, 2010 | HP Office Equipment & Supplies
HP 7210 Officejt is not printing
2. While holding the # and 6 button, connect the power cord to printer.
3. It will print the alignment sheet and you will have to re-align the printer and try to print/copy
*Note this is Semifull reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Or are you not able to print from PC ?
Link
Oct 23, 2010 | HP Officejet 7210 All-In-One InkJet...
How to set a printer to print only 1 copy no matter what # is put
You cannot do it -- when you request '3' copies, the computer sends 3 times as much text & commands to the printer. So, the printer cannot tell when the 2nd and 3rd copy begins.
Sep 14, 2009 | HP LaserJet 1200 Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hp Photosmart C4100 series (copy 6) printer missing!
check you printer's properties settings
file, print, properteis or preferences
on the main/general tab
check that your set to
" printing all pages "
and not from-to ( this will only print so many )
hope this helps
Regards
Richard.
Apr 22, 2009 | Office Equipment & Supplies
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
Printer only printing 1 copy
make sure that you are using the correct print drivers
Sep 03, 2008 | HP LaserJet 2420 Printer
347 people viewed this question
jasbo
jasbo
