My simpson esprit 600 is not agitating during wash cycle it only goes one way
  • combantrim Aug 18, 2008
    During wash cycle agitator only spins slowly one way, everything else is fine, except sometimes water doesnt drain from machine and you have to physically blow in the water outlet to start draining cycle. (2nd problem doesnt seem related)
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Posted on Dec 03, 2014
5 Suggested Answers
SOURCE: Simpson Esprit 650 6.5kg Washing
I have just had the same problem occur with my washer.
I found that the hot would work but the cold would not.
The fault is the cold water valve.
This is the part that the hose screws to at the back of the machine.
To have a look at it unscrew the top of the controls at the back and you will
find the valve.
Follow this link for the part.
http://www.alliedappliance.com.au/info/A864810001.html
Posted on May 21, 2009
SOURCE: Simpson esprit 550.The agitator is not moving in
Had the same problem with mine, could be a number of things but in my case it was a relatively simple fix - but you'll need to buy a part.
Open the lid and look inside, the bit sticking up in the middle of the machine is called the agitator. Remove all the fabric softner and lint filter from it and you'll see one very small bolt at the base.
I concocted a number of ratches stuck together to reach it but once undone you can pull the enitre agitator up an remove it.
The agitator is driven by metal bolt with teeth at the bottom of the tub, however the agitator itself is made entirley of plastic, therefore (prob due to age) the metal teeth had eaten away the inside of the agitator and so it was just spinning inside its hole!
eplace the agitator and problem solved.
Posted on Dec 06, 2009
SOURCE: Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Posted on Jan 14, 2010
beltronic205
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
How to remove agitator from Simpson 750 esprit
Look down inside the agitator. At the bottom is a hexagonal bolt. You need a 10mm socket on a long extension bar to reach it and undo it. Then pull agitator up & out.
Feb 15, 2017 | Simpson Washing Machines
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
Simpson esprit 550 agitator & spin not working properly.
Open the lid during the wash cycle and observe the agitation, you need to see exactly whats happening, If its corkscrewing instead of agitating it will wind the clothes as you described. Agitation is usually back and forth, or up and down etc, not just turning constantly in the same direction.
Aug 25, 2014 | Washing Machines
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson esprit 550 washing machine stops mid-cycle
Mar 31, 2010 | Washing Machines
Dec 27, 2009 | Washing Machines
Simpson Esprit 750 washing machine timer?
Hi! My Simpson Esprit 750 washing machine won't click over to the next stage in the cycle. All of the stages work if you turn the dial manually so I am wondering if it may be the timer that needs replacing? I can't hear it in operation. Thanks.
Nov 15, 2009 | Washing Machines
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
271 people viewed this question
Top Washing Machines Experts
