Question about Mitsubishi VS-45607 45" Rear Projection Television
Help!!! there are three lines ate the top of my tv a red green and blue. and the screen bounces every once in a while what can i do and how much do you think it will cost me ?
  • 1 more comment
  • johnbjrn Aug 24, 2008
    my sreen bounces and has lines across the sreen.
  • Anonymous Aug 26, 2008
    I was just given this tv and it also has three lines on tthe top and also starts to bounce afrter 5 minutes or so.what can do to fix the problem?
  • g_david May 11, 2010
    um how much would this all cost
  • 927 Answers
Good Day;
This common for this TV; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Good Luck, big IRISH.
Posted on Sep 26, 2008
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
I have a projection tv that the pictures ghost and the red and green and blue do not line up on the screen. There is allso lines across the top of the screen and are red,blue,green. Looking at the screen...
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Lines on the screen
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
Feb 14, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Green, red, and blue lights don't line up on screen
hi you have faulty convergance ic also there may be some faulty resistor and capacitors that sit in front of the ic, thanks
Jun 27, 2017 | Hitachi 50SBX78B 50" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
Double and bouncing lines
Jan 12, 2008 | JVC AV-48WP74 48" Rear Projection...
Lost the picture
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
