Hi
just try this link
Then Download the correct model manual
i think it may useful to you
There is a rate option "Was this helpful?" Yes or No.
If you are helped you can rate, that is your choice.
Testimonial: "Thanks Carol "
hi
just try this link
To adjust the ringer volume:With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings
