Question about HP OfficeJet 6110 All-In-One InkJet Printer
Fax i can receive faxes but when i want to send faxes i get the message error 344
  • 138 Answers
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Posted on Aug 26, 2008
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
HELP ERROR 344 ON MY HP J4680 CANNOT SEND OR RECEIVE FAXES
Welcome to FixYa!
There are 4 reasons for Error 344 to occur when sending or receiving afax.
1. The remote machine failed to respond to a fax command from the local machinebecause the connection was interrupted. These errors can occur if the phonelines in the area to be faxed are old or there is noise (static on the phoneline). Other reasons can include power outages and other power-relatedproblems.
2. The call-waiting service can cause this error. The click, heard for anincoming call, is actually a momentary disconnect of the line.
3. The remote user pressed the Stop key while the reception was in progress.
4. Under rare conditions, incompatibility between the two machines might causethe remote machine to abandon the call.
Solution 1
Try to send a fax at a different time when telephone line conditions haveimproved.
Souliton 2
Try sending at a lower transmission speed.
Keep me posted and thank you for using FixYa!
Jas247
Mar 08, 2011 | HP J4680 Office Jet All-In-One Printer
I get the error 344 message continuously to this one number i'm trying to fax to. i can fax to any other number, but this one # almost always produces this error 344?
Then the problem is most definately on the fax you're trying to send to, and not on your machine. If it works to all other numbers but not to that specific one, then you can shift the blame to the other guy.
Jul 28, 2010 | Office Equipment & Supplies
The most often, when I send or a facsimile to RSA
Probably has something to do with the protocol that faxes share. Have you tried any other RSA faxes? It may be that they have an old machine. Most new ones can handle any protocol.
Oct 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My m1522nf keeps erroring out with errors 244 and 344 while receiving faxs. It also will not send more then 6 pages. Any Idea's?
These are typical comm errors, try installing a line filter and turn the ecm mode to off and the fax speed to medium.
Al
Oct 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Error code 344*
Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
check here for more information
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
788 people viewed this question
Seeker5211
Seeker5211
