Question about Mitsubishi VS-60601 60" Rear Projection Television
Picture one day, no picture the next
My wife turned off the VS60601 [serial 108445 purchased 5/98] after watching the Olympics and went to bed. Next day she turned it on, the green power light works, the sound works, but absolutely no picture, not even "blue screen" when cycling through the 'input' button. Picture quality did NOT seem diminished in any way prior to the failure. I'm thinking a fuse or the like but can't tell where they are. Or the power supply to the 3 tubes is out? Or? This is the first problem with the set in 10 years.
  • 10,594 Answers
If you are tech-person, can understand it easily. TV needs G2 or Screen Voltage adjustment and its not big problem and if your non-tech person, let me know to guide you further.
Posted on Aug 19, 2008
  • 6,487 Answers
This can be problem with the tube itself, because for almost 10 years you never had problem with this TV and now the tube may got bad already and may need a replacement already...
Good luck.........
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
    Master:
  • 521 Answers
Try resting the device again for few hours n then try
  • tech expert12 Aug 19, 2008
    Some kind of power surge may have damaged the high voltage power supply in the TV. The problem may only be a fuse for the hv power supply section. To be sure that the hv power supply is running or not try bringing up the on screen menu. If you do not see the menu you may want to take off the rear cover and look at the ends of the picture tubes to see if they are glowing slightly with the TV turned on. If you do see the picture tubes lit up, the problem is most likely a no video problem
My tv's picture just went kaboom! We have wonderful sound but sadly no picture. : ( Please help me turn my frown upside down! Thanks so much!
First of all I would contact the company and see if there is a recall on the set as this sounds dangerous and could burn someone's house down. If there isn't a recall I would request one be open at http://www.cpsc.gov/about/contact.html You may save someone's life by doing so. As for the TV it can be a number of things. If there is a recall the TV should be fixed by the manufacturer for free. If not get a quote from the local repair shop and see if it's even worth fixing or just buying a new one (OF A DIFFERENT BRAND) lol. Also please include the manufacturer and the model# next time you ask a FixYa question.
Dec 29, 2012 | Polaroid Televison & Video
Lg50pc1d purple screen
try to unplug the set for a period of time?
Mar 12, 2012 | LG Televison & Video
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
No picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Jan 13, 2010 | Philips Magnavox 42MF521D/37 Television
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
VS60601 Picture yesterday, none today
That model will usually leak coolant directly onto the vertical output area and that will put the tubes into protective blanking and you will have sound but no picture.
Aug 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Hitachi 60vf820 ultravision
Good Day, bgblueeyess;
Your somebody is wrong; replace the LAMP.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
