Question about JVC GR-D50 Mini DV Digital Camcorder
JVC lense cap problem.
Did you end up finding a solution to your problem? I have the same issue, but mine no longer starts working after a while. It's disappointing as we have a new baby and would like to capture precious moments but can't!
I'd appreciate any advice if you have any.
  • leannemorris Aug 19, 2008
    Haha! Thanks, sleeping better than expected so happy about that! I actually phoned a JVC repair shop and they said it's a common fault with that model and JVC are replacing the faulty part free of charge regardless of warranty! I took it in today and it should be fixed soon!
    Just google a JVC service/repair centre and you should be able to find one near you!
    Thanks!
    xxLEAxx
The only thing I found seemed to be that if I pointed it straight at the sun or some other brigh light it then seemed to start working.  I haven't done it enough times to be sure that this always works but I assumed that somehow it needed enough bright light to trigger something.  Let me know if this, or anything else works for you.  Good luck with the baby, try to get some sleep.
Posted on Aug 18, 2008
Lense Cap
the technology has malfunctioned
May 23, 2009 | Video Cameras
JVC home theatre system DVD/CD player has stopped working.
Please check the dvd layer lense. When there is lense problem this issue will occur.
Apr 03, 2009 | Audio Players & Recorders
JVC COMPACT VHS CAMCORDER MODEL NO. GR-SXM250U
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Feb 20, 2009 | JVC COMPACT VHS-C CAMCORDER
CAMCORDER SAYS LENS CAP IS ON AND SCREEN IS BLACK
I had same problem with mine. luckily for me a colleague of mine told me JVC repaired this common fault FREE and they did.
Give it a go. Good luck.
Nov 27, 2008 | JVC GR-D20EK Camcorder
LENSE CAP WARNING STAYS ON EVEN WHEN IT IS REMOVED?
Mine went back to JVC because it was a design problem. They fixed it for free.
Sep 20, 2008 | JVC Everio GZ-MG130 Camcorder
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Dan
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
JVC Camcorder GR DX95EK Lense cap problem
Contacted JVC, they fix this fault free,irrespective of the age of the camera
Mar 19, 2008 | JVC GR-DX95E Mini DV Digital Camcorder
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
JVC Digital Video Camera won't recognise that the lense cap is off
No Prob...I had the same problem with my GR-D72U. There is a defect in the CCD image sensor. JVC will fix it for FREE! All it will cost you is shipping it to them. Go to http://www.jvcservice.com/service/CustNoticeCamcorder.asp?PgReq=DspDtaDtl&MdlNbr=GR-D72US&Pgm=CCD , download the rapair request... Send it off to your nearest service center and they ship it back all fixed up in less than a week. I must tell you though, you ONLY have until Dec. 31 2008 to do this. Not only did they fix mine, they cleaned the heads but also buffed out a scratch. After you get yours fixed, post as many helps as you can to others.
Jan 09, 2008 | JVC GR-D50 Mini DV Digital Camcorder
Lens Cap Problem
I saw something about this on another support board. I think it was on pechorin.com. I can't be sure but it sounded like this is a known issue for JVC and they were extending their service and doing post warrenty fixes.... Might want to check this site and/or contact JVC. Good luck
Apr 09, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
JVC GR-D50 Mini DV Digital Camcorder Logo
35 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
