Question about Refrigerators
Insulation You said: Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system. When I removed the panel, the piece of insulation attached to it is falling apart. The fabric -like cover is broken and the fibrous material is falling out in clumps. I'm afraid the clumps of material will cause the fridge to not operate properly, but am also worried that the lack of insulation could be dangerous. I would like to take the insulation off, put the panel back on and use the refrigerator to keep our food cold for tonight. Is this a problem? Thank you.
  • ElsaB Aug 24, 2008
    Thank You! I have been struggling with the refrigerator for a couple of months now because we don't have enough money to get it serviced. It seems that if I defrost it about once a week, I can get it to cool down again. Meanwhile, I have been trying all the things that seem approachable to me, like cleaning the condenser coils.I did get really worried about that insulation and appreciate your help!
  • Scott Wright
    Scott Wright May 19, 2017
    get more information about insulation material fromhttp://aerolaminsulations.com/
  • 828 Answers
The insulation you spoke of is only for dampening sound that may come from the compressor area. You can remove the loose material and it will not cause any problem. The panel determines proper air circulation over the compressor and condenser.
Posted on Aug 24, 2008
  • James Helmer
    James Helmer Aug 25, 2008
    If your refrigerator is supposed to be a frost free model it will have a defrost timer at some point. Newer models are in the area of the controls in the refrigerator compartment. Some older models have the timer located in the back along one of the rails. In ether case there will be a round hole with a clutch head screw in it. By turning the timer screw Clockwise very slowly until you hear one audible click will put the refrigerator into defrost mode. Wait about 25 minutes and it should automatically go back into cooling. If it does not restart cooling after the time turn the screw a little more to the second click. it will then start cooling again. Having to turn the screw a second time indicates a bad timer.
    If defrost does not take place and the timer restarts the cooling on its own there is a problem in the defrost heater circuit.
    Glad to be of help.
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
Nov 06, 2017 | Refrigerators
Defrost drain is not working how do i locate and clear
the drain is located in the freezer section of your unit and requires that you remove the back panel to access it... if it gets clooged it will freeze the tube that runs dowen usually all the way to compressor area and heat from compressor evaporates it. remove panel and take a hair dryer start thawing its a long boring process but fairly easy make sure the hole in drain is clear and to make sure after thawed run a cup of hot water down and remove back cover on unit down near compressor and you should be able to see it go into a drain pan under refrigerator....
hope this helps good luck to you...
Jan 06, 2011 | Refrigerators
My refrigerator had started getting warm and the freezer stopped freezing.
Check the following:
1) Door seal gaskets for any wear and leaking - You can use the dollar bill trick between the base and the seal, close on it and try pulling out the bill, you want a little resistence - if the bill comes out easily your gaskets are not tight. (although this sounds like unlikely in your case)
2) Condensers at the back of your unit or at the bottom - using a condenser brush and vacuum cleaner, get rid of any excess dust - if your condensers are covered with excess dust your unit will not get rid of the heat efficiently and cause excess runtime on your compressor and it will take much longer to cool.
3) shut off your unit and remove the back panel of your freezer, look for excess frosting on the evaporator coils - using a blow dryer, manually defrost the evaporator and surrounding areas until everything is clean. Put the panel back and turn the unit on for a couple of hours, then check the cooling - if it returns to normal then you have a defrost problem and will need to have your control board serviced and check for the defrost timer components. Also make sure the evap fan is working and spinning normally. You also want to check your condenser fan at the bottom of your unit (if applicable, if you have condensers at the bottom).
If all else fails you will need to have service check your charge levels on your compressor and locate leaks if applicable - but the most common causes are defrost problems so check this one first.
Sep 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Does anyone know the reason my subzero 532 is frosting at the corner just above the vegetable glass self close to the freezer side. The icemaker is also not workin. May be just coincidental
sometimes you have bad insulation problem. on your panel at back of fridge. you must remember that there are condensing pipe running between your panels and if there is a wwekness in your panel insulation, you can get ice buildup on your panel because of condensation. you can get liquid foam to repair the problem. find the position from the bask of the fride and remove the insulation foam in that area. most of the new type fridges have a type of plastic corrugated cover at the back. it is easy to remove a piece and replade it with any kind of covering. its a messy job so goodluck my man.
Sep 06, 2009 | Refrigerators
Best way to access AC compressor on 2006 Jetta to replace it?
1. Make sure the vehicle is off with key removed.
2. You need to evacuate the refrigerant with a refrigerant recovery system.
3. Remove the ribbed belt.
4. Remove the noise insulation beneath the engine.
5. Remove the bolts (1) from A/C compressor and disconnect refrigerant lines.
6. Remove hex screws (2) and remove the compressor.
Reinstall in reverse order making sure the bushings (3) are seated. Make sure your new compressor is filled with regrigerant oil prior to install and you do not start the car prior to filling it back up with regrigerant. Turn the ribbed belt pulley of A/C compressor 10 rotations by hand before starting the engine.
Aug 03, 2009 | 2006 Volkswagen Jetta
What is involved in cleaning the compressors on commmercial reach-in coolers?
the compressor itself can be cleaned with any mild cleaner/degreaser and a rag (the fins are aluminum and the tubing is copper, so no heavy-duty cleaners). if you mean the condenser (coils), compressed air works best. if the pressure is too high or the hose nozzle too close, the fins will bend, so be careful. if the dust/dirt/obstructions are really coated on the fins, there are cleaners that you can spray on. as long as you know can clean what's behind it and can soak up the puddles, you can spray simple green, let it set for a little, then use the air hose to blow it out. you can use a fin comb to straighten out the bent fins. for the evaporator fins, just use air.
Jul 20, 2009 | Kolpak WARRANTY-3/4HP 5 Year Walk-In...
Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Jul 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool refrigerator door is hot to the touche around the insulation
It should be warm but not hot. Check the fan in the back of the unit by the compressor, that is the condenser fan, make sure it is turning and not full of lint or hair. Pull out the refrigerator and remove the cover at the bottom, you may need a 1/4 inch nut driver to remove the screws, this is where you will find the fan.
Jun 15, 2009 | Refrigerators
Kenmore cold spot refrigerator freezer
I would look to the condenser where the heat is removed from the refrigeration system for your problem. Check and make sure the condenser fan operates, check the compressor for operation. If the condenser is plugged with dust it will cause the compressor to cycle on its thermal overload protector. Normally in back there is a removable panel to access the condenser and compressor area. make sure you reinstall the cover after you are done. It is critical to proper operation and cooling of the system.
Jun 01, 2008 | Refrigerators
Maytag side by side
Sounds like a compressor problem. Unplug it and check the condenser for cleanliness. Clean if you see any dust build-up. Condenser may be located in back behind a removable panel. be sure to reinstall the panel when you are done. If the compressor is hot allow it to cool off and plug the refrigerator back in. If you get a hum and click from the compressor call for a service tech.
May 22, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
