Question about Cadence A7 HC Car Audio Amplifier
Cadence A7 HC not working
I got a Cadence A7 it does not want to work. Goes directly to diagnostic.
  • makjr13 Aug 18, 2008
    I was just thinking of paying to get it fixed because i don't want to try fixing it. I am scared i might just mess it up more.
  • izzy2526 May 11, 2010
    My amp fried my ground wire on my wild beast sub. I resodered it back and hooked it back up and now it keep going to diagnostic. Even with it not hooked up. What should i do. should I send in please reply soon. thank you.
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protection - Troubleshooting
Let me know if you have any other questions.
Posted on Aug 18, 2008
SOURCE:
Vdo m5 bike computer has no speed reading . Cadence reading is fine. I replaced all new batteries. Just can't make it work, sometime display shows transport . Don't know what is that meaning ?
The computer goes into Transport Mode when it detects the bike is moving without the wheel moving (as on a car carrier) so that means the wheel sensor is not working. If you take a magnet and pass it right by the sensor several times and get no cadence count then the wire is broken or the cadence portion of the computer is non-functional. Unless it's the wire and you can fix it you need to buy a new computer.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Aug 18, 2017 | Cadence Cycling
How do i trouble shoot a delphi 4.0 bike meter. every feature is working except the cadence? is there a battery in the little unit that goes down by the rear wheel
First, make sure that the sender is connected. There should be a device on the frame over which the magnet attached to the pedal passes. Unless you have the sender that is attached to the pedals you will obviously not get a cadence. secondly, on my Vetta device one has to select cadence. Check the manual to find out how to do that. I'm sure there is one online.
Aug 19, 2012 | Cycling
Sigma BC 1609 Cadence Bicycle Speedometer reads my movement much slower than I am actually going. E.g. moving about 15, reads as 5 mph.
I had the same problem. It is caused because the mount is facing the wrong direction and your computer is swapping speed and cadence. 5 mph would mean 63 RPM of the wheel which probably what your pedal is actually doing. The wheel is actually turning at about 3 times that rate so if you check your cadence it is probably maxing out at 180 even though that wouldn't be possible.
To fix this, just twist your mount 180 degrees on your handlebars or stem and try again. That way the computer is correctly lined up with the mount.
Mar 10, 2012 | Sigma Sport BC 1609 Cadence Wired Computer
THE PROTECTOIN AND POWER LIGHT KEEP FLASHING ON AND OFF
The prtection light normally responds to impedance problems with speakers....try diconnecting all speakers and see if situatioin continues,.........with the power light, ensure that you have proper grounding of the a,mplifier as well as insulationa dn fuse protecxtion mounting for the powe supplies
Sep 27, 2010 | Cadence A7 HC Car Audio Amplifier
Can I use a sd hc card in my Sansung A7 Camera or does it just have to be a sd card
Your camera does not support the SDHC card. So you should go on to use the normal SD card.
Apr 01, 2010 | Samsung Digimax A7 Digital Camera
Machine error A7
A7 says that the scanner information in the eeprom is corrupted. The scanner is the wrong type. You will need a shop to do the eeprom clear in the diagnostic mode.
Jul 02, 2009 | Brother MFC 420CN All-In-One InkJet...
External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Jan 08, 2009 | Toshiba Advanced Port Replicator III...
Have a a7 Hc... Blown transistors.. Shematic diagram??
What are the part numbers on the transistors you replaced?
Did you replace transistors in the output section and the power supply section?
Does this amp have the defaced ICs labeled B52 and F16?
Jun 21, 2008 | Cadence A7 HC Car Audio Amplifier
Diagnosis light
It could be an overheating or power issue. It may be that the two speakers are loading it too much, which will cause it to overheat. Does the light eventually go off and the sound return ? Do you have the speakers wired in series or parallel ? What's the impedance of the speakers and the minimum continuous load for the amp ?
Nov 20, 2007 | Cadence A7 HC Car Audio Amplifier
Cadence A7 HC Car Audio Amplifier Logo
418 people viewed this question
Top Cadence Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Dalynn Turner
matthew walsh
Level 1 Expert
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
