Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Water on bottom shelf of FRT15B3AW3
Refrigerator gets water on bottom shelf (above crisper trays). Adjusting the temperature does not seem to work. Help!
  • 2 more comments
  • JOHNNYBAQUE6 Sep 08, 2008
    MY FREEZER IS FROST AND IS LEEKING WATER AT TTHE BOTTOM
  • Anonymous Sep 25, 2008
  • gmooney1 Oct 16, 2008
    Same problem.  However I have in the past I have had to clear the water drain in the freezer of ice. And the Tube running to the floor of the frig was iced up also.  well its doing it again.  Any suggestions?
    Problem Solver:
  • 15 Answers
Is the fan still running in the freezer compartment???? it may be your defrost thermostat.....
Posted on Aug 18, 2008
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Why do have water below my lowest shelf
your drain line may be plug up therefore is going above the level make sure you see water on the bottom tray next to the condensing coil under the refrigerator.
thanks.
Aug 11, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Vegetable crispers and deli tray freeze food.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Feb 15, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Fruits or vegtables freeze in crisper drawers
Hi
The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:-
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Please check the link bellow to have a detailed idea of how to store food or in what temperature in refrigerator:-
http://www.ehow.com/way_5670387_storage-tips-vegetables-humidity-drawers.html
Please get back to us if you have further query else please accept the suggestion.
Feb 01, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Freezes Refrigerator Barely gets cold
Hello there:
Here is a few things to check to make sure the referigerator is working properly.
The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,
Apr 14, 2010 | KitchenAid Architect 24.5 Cu. Ft....
Cracked border to bottom shelf of frigidare refrigerator
240350614 is the part number for the shelf border that you need...price is around $26
Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
I have an all fridge model with water accumulating under the vegetable/crisper bins. Like other I have read about here, I have to sop up the water at least twice a day. I have had this refrigerator for...
I have also had a similar problem with twi different fridges. The first I fixed by unblocking a tube that runs out of the back to a tray underneath where the water goes and evaporates naturally, this was a very old fridge. The second was because of the door seal. I replaced it and it was better but not perfect. I then realigned the door, which seemed to cure the problem. I sold the fridge a year ago, and the guy who bought it says it works fine.
Nov 30, 2017 | Whirlpool EL7ATRR Refrigerator
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
217 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
