Question about HP PSC 1315 All-In-One InkJet Printer
Hp 1315 won't scan
When I push the scan button I get a message saying "no software for scanner." It always scanned before.
  • xoerikasays Aug 19, 2008
    i can print stuff but te scanner does scan when i click the scanning button
  • 234 Answers
Are you able to scan from the software installed in the computer:
If you have a icon saying HP Director / HP Solution center, if not go to Start> All Programs> HP And then HP DIrector / HP Solution Center and then try to scan from there if yopu are able to scan from there then go to> Settings in HP Director / Solution> Then Scan to setup> You should see a option which says Destination list> There down bellow you should see a option which says RESTORE DEFAULTS> Click on that and then apply> and close all the screens and try to scan from the All-In-One printer.
Good Luck
Posted on Sep 01, 2008
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 and Vista, to scan a text, not a picture
Just to try....
The Scanner software should have an option to choose image or text, image and text etc.. Look for that first.
Do a scan but before you do and run through the process as you normally would.
Put the printer/scanner CD in the carriage cancel auto-start. My HP different type but... does not always see/grab ALL of the scanner files on an install. Sometimes however, it will go looking for the files it needs and grab them off of the CD when it actually NEEDS them. When you try to actually to the scan. Otherwise the printer probably works perfectly right.
If you want to check it out just for the sake of it. Look in Windows explorer - control panel and see if there is actually a scanner listed or just a printer? Good luck!
Feb 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HPSC1610 all in one
Im very sure that you encountered that message when trying to scaning using the HP Director / HP solution center. Here are the steps that i want you to do inorder to solve the issue.
1. Insert the CD that you used to install the Software.
2. The Window for installation will pop-up, CLICK ON UNINSTALL. (note: make sure that you unplug the usb cable from the back of your computer before uninstalling the SOftware).
3. When done, restart your computer.
4. Re-insert the CD and Click on INSTALL.
The reason why you encounter such problem might have something to do with the corrupted components of the Software installed in your pc.
Thank you so much.
adonscott
Jul 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner hp 1315
Hi -
I don't have a Mac, so not entirely exact on your solution. But, I do have a suggestion to try -
if you use a scanner, you probably have a photo editing software of some kind (like Photo Shop, Paint Shop Pro, etc etc). Within that program, there is an option to obtain the image from a scanner. You should be able to use that function instead. I know that with my WinXP, I could import from the scanner in Paint Shop Pro MUCH easier than trying to use the actual HP buttons on the 1315.
Please note that the 1315 will also only scan flat items well. If it is 3D, like jewelry or oddly shaped objects, you'll only get fuzzy-edged pictures. The 1315 has no depth perception, no matter what setting combination you use. Not HP's finest moment, for sure. I had this printer for a month or two before I was fed up, and went back to a separate printer and scanner! : /
May 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner, scans and then re-scans.
you can go direct open my computer then you will find in the my computer window icon for HP officejet 4300 if you press it you can go ahead with wizard that let you scan your photo or document fast you can even send short cut to this icon at the desktop so you can reach it faster
 OR   ~~~~~~  another solution
when you open the hp software press the scan botton then will open another window has two option choos scan and then choos scan again in the other window
Please rate me if this solution was ok thank you
Oct 15, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 Scanning problems
download software for hp psc 1210 printer
Oct 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
1,096 people viewed this question
Ben Johnson
