Question about Kenmore Dryers
Kenmore gas dryer runs but not heating
My 13 year old gas dryer stopped heating today. The drum still turns, though. I checked the vent to see if it was clogged but it wasn't. Is it just old and needs replacing or is it fixable?
Try replacing the valve coils first, then the valve if the prior doesn't work. If there is a buzzing noise, I believe it's more likely the valve. I'm replacing both on mine to be sure.
Posted on Sep 16, 2008
MAYTAG LEGACY DRYER IS 3 YRS OLD TODAY AND HAS STOPPED HEATING. BREAKERS ARE NOT TRIPPED AND PROPER VOLTAGE AND VENTING IS WORKING PROPERLY. HOW HARD IS IT TO CHANGE THE HEATING ELEMENT? THANKS FOR THE...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Dryers
Takes to long to dry. installed new heating element, new tstats and i noticed that there was a gap on the back gasket drum. this will allow air that is not heated to enter the drum causing a longer dry...
Worn gaskets will cause some extended run time, but 75% of the dryer problems I repair are directly related to improper venting. Check that first. Pushing air thru the clothes is just as important as adding heat. Vent connector in rear should be rigid metal or heavy metal flex. As short as possible with no kinks. An easy way to check vent is to look at element when dryer is running. Should glow soft orange, not red hot or white . Try it with venting attached and then removed. If element glows less brightly with vent off, then vent is restricted.
Jan 13, 2011 | Kenmore 500 6952 Dryer
Dryer runs but the air doesnt heat up, what problems can it be? i have a kenmore 800 series and it worked fine then just stopped heating. i pulled it out checked the vent to make sure it was clean.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 02, 2010 | Kenmore 800 7982 Dryer
Our dryer has no heat. The drum turns and we checked the vents. All clean. Also we checked the fuse. Is there a heating device? It's 5 years old. Thanks Cathy
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 23, 2010 | Whirlpool LEB6300 Electric Dryer
My Gas Dryer has stopped heating. I've checked the breakers and reset them...if the thermal fuse is bad, will the drum still turn and dryer run but not produce heat? I thought I had read that the dryer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Hi, I have a kenmore gas dryer Model # 11077532600. When I first turn it on the gas runs then shuts off after about 5 to 7 minutes. I experienced this problem a year ago and we had the thermal fuse...
heatman101
Sep 02, 2010 | Kenmore Dryers
Dryer runs but does not heat
The most common problem with gas dryers is the ignitor...
Check out this tip that I wrote about this...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 04, 2010 | Estate TGDS840JQ Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
New Dryer, drum turns but no heat.
Check your breaker. Reset it.
Apr 22, 2009 | Dryers
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
