My TV is fine...problem happen when I was moving today,not sure what its called but its the silver projection located on the back of the TV is which you connect the cable on the wall too...it broke off??what to do??
  • 44 Answers
Hook the cable up to the VCR or if you don't buy a RF converter from radio shack or electronics store which will have a coax connector on it with component and Svideo to send to the TV. Select the connection (Component or Svideo) in the TV menu. If you only have the coax connector on the back of the TV without any other connection, you will need to get that tuner board replaced.
Posted on Aug 18, 2008
I have a Toshiba tv model #50vf820. It was recently transported to a different location. At that time, it had been working fine. Since at the new location, the fan is loud when the set is turned on. O
sounds like it was banged around take off back it sounds like something is in way of fan now should be able to move it or call professional
Mar 27, 2014 | Televison & Video
MY WHEELWRITER 6 WAS WORKING FINE UNTIL TODAY IT STAYS ON THE LEFT HAND SIDE AND WILL NOT MOVE TO THE RIGHT. IT MAKES A LOUD NOICE. I DO NOT SEE ANYTHING STUCK AND THE BELT IS INTACT HELP
Check for objects and debris under or around the carrier, with it off see if you can move the carrier back and forth, check the battery pack to be sure it hasent be come disloged. If you can move the carrier put some WD40 on the silver shaft it slides on.
DickyO
May 13, 2010 | IBM Office Equipment & Supplies
RCA projection, no power, no sound. recently moved.
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Exactly same problem just happened today! Only power button on the TV set and remote control works, no sound
I had this problem happen to me today. What i did was unplug the tv for an hour and when i plugged it back in, the first time setup appeared on the tv. The remote and the tv buttons worked fine after that. Hopefully that works for you too.
Jun 06, 2009 | Panasonic PT-52LCX66 Projection Television
Samsung HCN2446W -- Yellow/Greenish tint all over screen
That model should be HCN4226W, right? Because the other don't come-up. Sounds like the mirror may have moved. It's mounted on the upper part of the back of the T.V. Should be flat against the back. Check that. Then see if all 3 tubes are lighting up. Also possable the fluid leaked out.....but not likely. These sets are fairly robust. Do you remember jarring it in the drive home?? Did you have it laying down when you moved it?
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red Gun screwy!!
You have a typical convergence problem here that happens on just about every tube type projection TV set ever made. There are two STK IC's that will need to be changed. Best thing to do, if you have any soldering experience on printed circuit boards, would be to get the service manual, locate the convergence amp IC's order the correct parts and not any replacement IC's that cost less the 20 bucks, and change the IC's. If you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jun 30, 2007 | Panasonic PT-47WX49 47" Rear Projection...
T.V. dead
Sounds like something has shorted out, the "three beeps" are they loud or softer, high pitched or low, would suspect that you might want to call someone out on this as it could be a number of things.
Feb 15, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
