Nintendo DS Lite Console Logo
Posted on Jun 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dead would not power on - Nintendo DS Lite Console
Computerfixedfast
Level 2:
New Friend:
  • Expert 127 Answers
  • Posted on Jun 04, 2011
Computerfixedfast
Expert
Level 2:
New Friend:
Answers
127
Questions
Helped
13473
Points
157
Have you tryed another battery???any more questions just ask please give positive feedback im trying to sort this problem out personly you with untill its gone so please at least give me positive feedback and i hope we can fix your problem together.thank you
Why would doesn't my Extensa 4420-5910 power up?
Acer EXTENSA 4420-5910 Laptop
2008? +Vista home loaded. new.
you meant that?
dead PC, no full evidence told. is screen dead,fans dead an all LED dead, or beep codes or LED blink codes or text errors to the screen and all that is dead, that is a 100% dead PC or just dead screen
just bought it dead as most this old are dead, from $1 garage sale>?
this screen has CCFL back lamp;s and 99% are dead now world wide, at 20,000 hours on them or 5 years 10hr/per day. dead.
if seem to be on and LCD is dead use flashlight dark room
pointed LCD, if see data now that tells you CCFL tubes are dead
in 30seconds work, amazing no?
here are are the tests, for 12years lold
the CMOS battery in side is bad, dead, and can not be ignored.
remove old battery huge leave it out until PC runs again right.
run on correct AC power pack do not mix it with others wrong.
power on , hold this button for 10 seconds and release (intel reset)
does he power button LED work, LED power glows
fell or hear fan spin , yes too.
then do this
http://pcdied.com/monitors_and_screens/flash-light-trick.html
the flashlight test trick, do this if fan blows.
and or hammer he BIOS hot key F2 as you release power button
this puts up BIOS screen .
the laptop can be connected to a monitor if your CCFL dead
and run like that for ever. (zero portability)
VGA monitory
power on and hit, Press Fn+F5, LCD/CRT/both display switching
seen on page 89 of your manual.
set it to both blind. if CCFL is dead, or to CRT
CRT means external VGA (legacy named ectreme )
Asus x553m won't power on
what is it, ?
2013 made, M means mobile
black screens , Asus logo dead, screen dead black ,BIOS dead. login dead, with power button held for 10 full seconds. ok?
sure it is dead are not all that old dead, for all this classic reasons due to ITS AGE.
1-the big huge battery is bad, remove it run on AC power pack only even forever. battery here can short and overload power.
2: coin cell battery inside dead, as all are this old. replace it.
7 year max and is close to end of life.
3; HDD dead, as most are this old (unless parked as a hanger queen unused for decade) we run smart tests on it.
4: CCFL lamps behind LCD DEAD> not your PCl. yours is LED good.,
so do the long reset first, big battery out , AC pulled
push power for 30 seconds, release
put back AC pack only , and see that BIOS works
report if the all BIOS hot keywork next with SCREENS BIOS all working, this is first step on all PC made this.
(not apple bs)
The bios most work even with HDD removed.
remove all USB toys first.
2answers
Samsung lcd monitor b2030 power on problem
is the power LED actually dead?
is the screen 100% dead
is he front menu OSD button dead.
if yes, yes, yes, then the monitor is DEAD. of AC power is ok.
learn this fact all monitors before magic year 2010
are dead, due to CCFL back lamps burned out.
and will cost 2 times new, to fix it.
your manual shows year 2009
if it try to buy screen it shows me , the main board has 2 highvoltage CCFL lamp jacks.
so CCFL are dead. most are, most died in the year 2014
if run every day for 5 years, they GO DEAD.
or less if run 20 hrs /day.
if parked on shelf for 10 years, it works. see? 20,000 hours life spans.
best is to buy a 2011 and up monitor cheap even used.
with LED back lamps. and enjoy a long lived monitor.
CCFL jacks right side ! back lamps that love to die.
1helpful
Changed out atx power supply because computer not powering up. Do I replace with same motherboard with same or buy new Windows 10 Box.
ok, a simple hardware question only. w10 could careless about PSU. (facts) mobo is micro atx size 24.4cm x 24.4cm
not powering up has many causes, even simply stuck in sleep mode. (power on button held for 10seonds and released last is 1 cure. of about 20 causes (up to)
GA-F2A78M-D3H (rev. 3.0)or rev. 4.0????? rev is on bottom left of mobo, normal tower case. no case told
the PSU is called ATX and all work here 500 to 750watts
24 pin power is normal
but CPU power uses 8 pin power plug PSU.marked ATX12v
psu lacking 8 pin, can use 4 to 8 adpater.
vast here work, in real ATX case not micro cases.
https://www.newegg.com/p/pl?d=psu+atx&N=4131%20100007657%20600014006%20600479294&isdeptsrh=1&Order=1
from you manual .
12vatx-undefined-undefined-0.jpg dead PC
are all fans dead.> that is dead PC.
the monitor must be good and connected the the VGA jack
if using GPU card then it must connect to the monitor
the BIOS screen must work or the PC is dead or GPU card is dead.
strip the PC down ,any thing in the PC shorted will make PC dead.
if strip down tests fail the PSU may be bad is its fan dead too?
both power connectors most be connected above or PC will be dead.
Screen won't come on, on my Viewsonic VSR220
WHY DOES THIS SEARCH SHOW.
The Viewsonic VSR220 no such thing.?
Turn the monitor around, 180
and see the TAG sticker with real model told
no PC told , what PC is this?
this ? VSD (D key is next to R) so huge typo"?
https://www.viewsonic.com/eu/products/lcd/VSD220
yes that is a PC (android)
but can do monitor like duty. too.
it needs service.
if screen is dead, it has power problems
as the screen must at least show a viewsonic splash as power is turned on.
try it on a 2nd room AC power jack yet:?
if in warranty take it back to the store
or call viewsonic for help.
the android PC can use an HDMI cable to a PC and works as a monitor.too.
the manual states
4.5 Connecting to HDMI-compliant Devices via Micro
HDMI Input
HDMI (High-Definition Multimedia Interface) is a compact audio/video
interface for transferring uncompressed digital audio/video data. You can
obtain the best user experience for video playback and gaming via HDMI.
VSD220 is equiped with a micro HDMI input for connection to an external
HDMI-compliant device. You can connect your PC, notebook, Blu-ray player
or any other HDMI-compliant device to VSD220 for high-definition video
display."
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PC
what computer is this, not told
Vestel 14MB02-03 (mobo labels useless)
Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.
Vestel does not sell PCs !
google shows no hits (zero). posted wrong PC model?
ahhhhh coded words off mobo white painted silk screens
sure
I see one hit on that number alone and shows LAPTOP PC MOBO
clearly
ok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????
odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorry
the model is on the bottom tab on laptops old
or in bios screen 1 told
now and answer for laptops old.
1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.
2: coin cell dead, sure it is that old replace it.
3: any of up to 20 other modules inside shorted out.
4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?
5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
121helpful
8answers
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 • Cell Phones
2answers
My flatscreen monitor (HP w19b) kept powering down. I would push the on button, and it would go on then power down after 10 seconds. This morning it wouldn't go on at all for about 1/2 hour, then started...
Hi sir, try to check for possible leaking or bloated filter capacitor in power supply board. That symptom might be caused by insufficient current draw from power supply source. Try to check sir. Maybe it could help. Thanks!
2helpful
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
Mobo does not power up Dead cpu dead mobo?
A dead CPU will not hinder a board from powering up. The board is unlikely to POST. However, you should heard attempts at powering up and immediate shutdown. Or, you will see the PSU comes on but system not boot.
No mobo, but, CPU.
If no failed attempts at boot, no indicator lights, then you have either a failed power supply or DEAD motherboard.
Good luck
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
