Question about Whirlpool GEW9250 Electric Dryer
Smelly clothes I'm not sure if it s it my Duet washer that isthe problem or the dryer?
  • Charlie2222 Aug 18, 2008
    Yes.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Is the washer a front loader?
  • 876 Answers
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Posted on Aug 18, 2008
My whirlpool duet hp washer has a musty smell. i have used bleach several times but so far no help.
Clean the washer with Smelly Washer Cleaner or such product. Never close the door when not washing clothes, leave it open to air out
Jun 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not working flashing code 02 f will not drain or spin and wash will not reset i have unplugged.
Disconnect from power. Make sure no clothes is in the washer and no water.Open bottom front panel. With bucket in hand remove filter lid and clean all smelly water and debries. Put everything back and try to start the wash again. That should do it. Good luck!!
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Odors
Unfortunately this is a common issue with low water consumption front loading washers.
Fortunately there is a pretty easy fix. There are products that work great in cleaning out the hidden area that the odors come from. I have put some information on this together, follow the link below to see how to resolve, let me know if is helpful.
Smelly Washer
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontend washer smelly cloths...need
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
May 11, 2010 | LG WM2688HWM TROMM SteamWasher
My Whrilpool Duet keeps "eating socks", I have to take the cover off, unscrew the drain trap and pull out yucky, smelly socks!
That is a common problem with the Whirpool duets. Small clothing articles, especially baby socks go through the drum lip to the drain pipe.
Best to buy a zip-up laundry bag and place all the small clothing items in there.
Best Regards
Ash
Nov 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet Washer has an extreme mold smell. I have
The mouldy smell.......what else?
try adding 2 or 2 cups of Sugar Soap Concentrate then fill the machine and leave it for 24 hrs.
Then put it through a wash cycle without any clothes.
If this fails to fix the problem you are looking at a complete strip down and clean out!
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smelly clothes after washing
yes musty is actually cooked soap
from the dryer
take a clean just washed towel and put it in the washer alone with no soap
turn on the machine and watch what happens you will see the suds start to form
with this unit, if your using too much soap it will be spun into the cloths and then cooked in the dryer
do one towel load without soap then cut you soap usage way back
anything more than a tablespoon is way to much
remember you bought this unit to save water
1/6 the water 1/6 the soap
and he should be less
Oct 24, 2009 | Maytag MAH2400A Front Load Washer
Clothes not drying
is this a washer or dryer if its a dryer you need to check the air flow where the dryer vents outside the house make sure it is flowing good it may need to be cleaned out
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET FRONTLOAD WASHER
I had similar problem, the front door seal can trap small items,socks,handtowels. I didnt figure this out for some months, each load of clothes had a foul, mildew smell, Check door seal for trapped clothes, run intermittent cycles with bleach only, no clothes, be sure to leave door open when not in use to air out , this will reduce smell.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
