Question about Mitsubishi VS-6043 60" Rear Projection Television
Picture just disappears...
I have had a good run with this TV! Over 8 years and NOT a single issue...till about a month ago. The TV screen will just go black after anywhere from being on 5 minutes or 1 hour. I am assuming I have to replace something. Is this a maintence type fix and something I can do myself? And what is it that you think I might need to replace. BTW, the TV POWER stays on; it is just the screen that goes black. Thanks for the help.
  • cac90277 Aug 18, 2008
    Thank you for the help. Looks like it time for a new TV. I will see what I can get for it on craigslist. If I can fix it and make a $100 or 2, I will. Thanks again.
    Chris
This is a problem that a repair shop must fix. One or two circuit boards must be replaced. Also several electrical connections must be resoldered because they have become loose.
I had the same condition happen to my set. My cost to fix the set amounted to about 350.00. I wish you luck.
Jerry
Posted on Aug 18, 2008
6ya staff
SOURCE:
Toshiba TV 24D1334B2 - Blank screen/no sound
Is it showing a power standby light? This might be a simple fix like a blown internal power supply fuse.
Aug 19, 2018 | Toshiba Televison & Video
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Replaced convergence board, but can't adjust convergence
Bad chips or faulty soldering....
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2009 | Zenith R40W46 40" Rear Projection...
Blue Line on
Your problem is simple. The problem is your pannel. You need a new one. If it is under warranty, have it fixed. If not buy a new tv.
Mar 14, 2008 | Televison & Video
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Televison & Video Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
