During our move the connection for the cable was broken off and we're no longer able to connect the cable wire. Can a new adapter be installed enabling for attachment of the cable wire.
  • Anonymous Dec 10, 2008
    cable connection broke when moved out of tv
  • 44 Answers
You can use your VCR to connect the cable into and then choose in the menu which output you want which is component or Svideo. If you don't have a VCR then go to radio shack or electronics store to get a RF converter which is for older TVs(really old) which didn't have a coaxial connector. Get the one that has component and Svideo on it. Then you connect the component to the TV component(or Svideo) input and select that input in the TV menu. Fixed!
Posted on Aug 18, 2008
On my newly installed car Radio the reception fades in and out while driving. New harness and new antenna adapter and regrounded unit. Any possible solutions.
One way or another, you have a poor connection from the radio to the antenna. Check the following and make sure all cables are clean and completely and properly inserted:
- a poor antenna cable connection to the adapter or from the adapter to the radio
- a faulty adapter
- a damaged antenna cable connector (wire in center pin)
- a damaged socket on the radio
Jan 01, 2018 | Cars & Trucks
My Jvc car stereo is not working when the weather is cold or during a cold start up
You may have a wire that's broken inside the insulation. When its cold the wires shrink and make no or intermittent contact as they warm up the wires expand enough to make contact. Disconnect the wires from the connectors. Attach a continuity tester to the opposite ends of each wire (one at at a time) move the wire around, bend it k*nk it etc., and watch the meter. If contact is good meter will read 0.0 and not move, if its bad meter will fluctuate between 0 and no display. Any fluctuation indicates a poor connection in that particular wire between the 2 test points.
Jan 21, 2015 | JVC Car Audio & Video
I am using powerline ethernet adapters from my pc to ps3 was working fine for 12 months uddenly ps3 will no longer connect to internet, however using wifi it will,having moved adapter to ...
A power surge during a storm can damage the powerline adapters, in a heartbeat. This is a very strong possibility and you may need to replace the adapter(s). If it fried one, it can fry them both. Was any other electroonics connected to the power outlets in the home damaged? If so, then you may be out of luck, and need to replace them both.
Oct 03, 2013 | Powerline Ethernet Network Adapter
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Internet connectivity is constantly cutting out. I have to DIAGNOSE CONNECTION PROBLEM get connected again every 20 - 30 mins.
Please do confirm wireless or wired connection. If wireless ,reset wireless modem,install new wireless software (third party) or make sure wireless adapter in good position.
If wired run winsock fix, make sure ur lan cable socket is not loose, or try differnt cable,check windows update or antivirus.
Jan 31, 2010 | Acer Aspire One AOA110-1113 Netbook
Laptop shows 'A network cable has been unplugged" every 5 seconds
The Cable may have loose connect to the RJ45 jack get another good cable and it will work. Also make sure that the clip on the RJ45 jack as not broken and make it click when you connect the jack to the Network port on your laptop
Dec 29, 2009 | Toshiba Satellite A75-S206 Notebook
Disintigrating belt that moves the tray of ink cartridges on prin
Yes, it's definitely cheaper to buy a new printer.
A new printer will come with a CD-ROM, containing the necessary instructions and software for use with the new printer.
Before you connect the new printer, insert the CD-ROM, and it should "guide" you through the whole "install" process.
Dec 08, 2009 | HP DeskJet 895cse InkJet Printer
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
