Question about Bosch 30 in. NGP 732 / 736 Gas Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
SUDDENLY ONE OF THE TWO MIDDLE BURNERS ON MY VIKING COOKTOP SIMPLY STOPPED WORKING. TURNING THE KNOB NO LONGER GETS GAS SUPPLY NOR CLICKING NOR FLAME. OTHER FIVE ARE WORKING. DID I SPILL SOMETHING INTO THE OPENING AND THAT IS WHy? CAN I REPAIR IT MYSELF,
PLEASE HELP.
STUART
A557@EARTHLINK.NET
  • A557 Aug 18, 2008
    NOT SURE WHAT YOU MEAN. THERE IS A CAST IRON GRID, OR POT STAND, OVER THE BURNER. THE BURNER HAS A REMOVABLE METAL ROUND BURNER, WITH HOLES ALONG THE BOTTOM, WHERE THE FLAMES COME OUT. NOT SURE WHAT YOU MEANT BY REMOVABLE FRAME UNLESS YOU MEANT GRID. BURNER WILL LIGHT NORMALLY WITHOUT THE GRID.
    THE METAL BURNER CAP HAS A METAL NOTCH TO MAKE SURE THE FIT IS CORRECT. THAT IS MOUNTED CORRECTLY. YES. NO FLAME, NO SPARK, NO NOISE FROM 1 OF THE 6 BURNERS.
  • A557 Aug 18, 2008
    geemarie
    i appreciated your interest.
    beleive it or not, i seemed to have fixed it by
    removing the cap, using comp;ressed air like you use for blowing your computer keyboard and mouse clean, and blew air into the open tube.
    also, i turned on and off the gas line a couple of times.
    suddenly i heard click click when i turned on the know of the
    nonworking burner, turned the knob on and off a few times, and yes, it started to work. not sure if the comp;ressed air blew away something inside the line, thanks for caring.
  • 876 Answers
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Posted on Aug 18, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 18, 2008
    Okay, My stove will not lite without the grid in the correct position, I thought perhaps yours was the same. When you turn the burner on, does gas come out? Can you lite it manually? ( Quickly and carefully) If it willnot deliver gas , then it is has to be plugged somehow. Does the burner look normal and clean?You might ask if anyone has spilled something on the burner. It would have to be a big spill though, and just to affect that burner seems odd. I believe that you are going to need a repairman.
  • Gayle Ashbach
    Wow You and I both learned something. I was about to suggest that you use some sort of blowing device on a low setting to see if you could blow it out.
    Thanks for using Fix Ya
The Viking gas stove - 6 burner - clicks constantly -- it won't stop. it has done this for years and usually goes off after a while but now it wont stop clicking. The burner that is not even on click.
The problem is one(or more) of the 6 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
Please note though, in a perfectly working cooktop all burners spaks at the same time and only the only one that has the gas flowing to it will ignite,that part is normal.
I hope this helps you to repair your cooktop,
Gene
Aug 08, 2011 | Viking Professional VGRT362-4G 36 in. Gas...
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
My VIKING 31" VGSU 101 GAS COOKTOP. All 4 burners can't ignite .If I light it will work
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Oct 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
VGSU 36" gas cook-top control panel paint coming off
I just bought a bank repo home in So. Cal. that has the same Viking range as you have. Yes, the black lettering has almost entirely rubbed off. on this one too. Not good for such an expensive product.
I bit the bullet and ordered a new panel from appliancezone.com
http://store.appliancezone.com
Part # PE40057
The price is about $75, $80 with shipping, which is a ripoff I know.
I plan to put a clear coat of sealer on it and let my wife know to treat it gently.
I was surprised how many people think Viking products suck. Lots of negative reviews abound on the internet. If I was to buy a whole new range I think I'd avoid this brand.
Cheers,
Andy Dale
Apr 22, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Bosch 30 in. NGP 732 / 736 Gas Cooktop Logo
536 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
