Question about Dometic RM2652 Refrigerator
Dometic RM2652 Works fine .But the light comes on to check .The temp in frigerator are correct . why the check light . thanks Scott Bailey scottbailey44@comcast.net
  • budwiser44 Aug 18, 2008
    rm2652 check light comes on . temp are OK .
  • 51 Answers
If your power supply changes such as shore to gen or any other source change the light will come on Try resetting If it continues you may need a voltage monitor to verify your not having other problems
Posted on Sep 07, 2008
Frigerator door seal is split,require new one. Were can I purchase one.
http://www.gas-refrigerators.com/pdf/RM2652-parts.pdf is a parts list for your unit. Parts can be purchased directly from Dometic by calling the phone number on the title page.
Aug 06, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 not running
dometic RM2652 will not run on gas... check light does not come on ... can hear the gas valve click
Aug 14, 2008 | Dometic RM2652 Refrigerator
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
142 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
