Can not print in black and white. Everything is printing in color red. cant find setting to change to print in black and white
  • Anonymous Mar 24, 2014
    i need to change settings on my mac to make my office jet 1800 print in black and white
    Novelist:
  • 158 Answers
On your windows desktop, left click on START. Left cllick on CONTOL PANEL, then left click on PRINTERS. RIGHT CLICK on your printers icon. On the drop-down menu, left click on PRINTING PREFERENCES. On th MAIN tab, look for a checkbox that says GRAYSCALE PRINTING, MONOCHROME PRINTING, PRINT BLACK ONLY, or a similar phrase for B&W printing. Check the box, left click APPLY, then OK. Print a test to confirm.
Posted on Aug 18, 2008
Hello, i cant print\copy. i get a message about empty cyan and yellow ink but i only wanted to print in black. do i have to change the other colors to print in black (which is full)?
Check the printer options or settings, Click Print and then on the pop up window before you print, instead of color select print mode as black and white. Then try again and see, if it does print try removing the colored cartridge and see if it prints. If it fails again you will need to play around with the options and quality of the printout.
May 11, 2011 | Brother Office Equipment & Supplies
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My Hp 1401 or 1400 all in one printer's software will not work on my new vista computer. I somehow changed the color to print a black and white photo, can't remember how I done it. Now everything prints...
  1. If you need to change settings, click the button that opens the Properties dialog box. Depending on the software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
  2. Select the appropriate options for the print job by using the features available in the Paper/Quality, Finishing, Effects, Basics, and Color tabs. (Color Tab should allow you to change from only Black printing)
  3. Click OK to close the Properties dialog box.
Nov 28, 2009 | HP PSC 1401 All-In-One Printer
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I cannot print in color even though I can print
What has changed?
Is it possible that the color cartridge is empty?
Check the driver properties and make sure that the driver hasn't been changed to "Monochrome", "Grayscale" or Black and White.
Don
Jul 02, 2009 | OKI C3200n Led Printer
Will only print in colour although the black is at 75% This is the 2nd time this has happened. Why?
the printer setting on many printers are set (by default) to print everything in color. change the setting to print only in black and white when you wish to print things in black only. HOPE THIS HELPS.......
Jun 15, 2009 | Office Equipment & Supplies
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
Black printing morphs into red after black ink cartridge installation
Your printer creates it's black by using ALL the colours together. This effectively gives a very dark purple rather than black.
It sounds like you have a colour cart that is drying up or may be struggling to get enough air into the cartridge. Make sure you have removed any tape over the vent holes if you are using compatible inks. If not then try running a couple cleaning cycles via the button panel/driver.
If you alter the settings in the driver by going into START - PRINTERS AND FAXES and then right click on your 2610 and select PROPERTIES - the changes you make in here will be set as the default settings for each print job.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
318 people viewed this question
k24674
jasbo
jasbo
