Question about RCA L26W11 26 in. HD-Ready LCD Television
I do not have a remote control for my tv i have adjusted the picture with only the keys on the tv i need an answer how to make the picture nstretch it looks better small i do not have a hdtv cable box
I need help i do not have a remote for the 26 inch hdtv model i have been using the top controls on the tv i do not have hdtv cable box so the picture is fuzzy how do i get the best picture
Call RCA's Parts : 800-338-0376
I believe the part number for the remote is 26-4852 I dont know how much it is.
Bestbuy also has it for $14 for the remote. just call 888-BES-TBUY and go to their parts department.
Posted on Sep 11, 2008
I have a Mitsubishi dlp wd-65737 that when turned on goes to a pink screen with no picture what could this be is it worth fixing
  • If your TV issues involve the appearance of your TV's picture, the remote may be your answer. Press the "Format" key on your Mitsubishi rear-projection TV's remote control if the shape of the picture seems incorrect. Press the key repeatedly to cycle through various aspect ratios until the picture looks correct. To restore all audio and video settings to their defaults, enter the TV's main menu and select "Reset" from the Picture tab. From the same tab, you can reset colors to their defaults by canceling optional image features such as PerfectColor or PerfectTint.
Aug 05, 2015 | Mitsubishi Televison & Video
My picture doesn't fit the screen
You have to adjust the ratio
Usually found on the tv's remote menu button
Apr 15, 2015 | Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Olevia 532 b12
There is a key on the TV remote control for adjusting the size of the picture. On pressing this key you will get the options of the picture size like 4:3, 16:9, Zoom, Wide etc. You can choose the size you like.
Jan 08, 2014 | Televison & Video
Picture too large for tv. Can't figure out how to adjust it.
There is a key on the TV remote control for adjusting the size of the picture. On pressing this key you will get the potions of the picture size like 4:3, 16:9, Zoom, Wide etc. You can choose the size you like.
Jan 08, 2014 | Sharp Aquos Televison & Video
Can I brighten the picuture my goodmann tv without a remote control
As there is no Menu button on the frnt panel of your TV, you can't do any picture adjustments, without its remote control.
May 31, 2012 | Televison & Video
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Remote code
Hello steeler,
I am David thank you for choosing FixYa.com for your answer.
I went to the comcast site and found the numers you have there is another way to try also here it is
Searching for a code If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
Example: You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
I hope this helps you with your tv Thank you again for using FixYa.com
feel free to rate me on my answer thank you again.
Nov 06, 2008 | Hitachi HL01453 Remote Control
RCA L26W11 26 in. HD-Ready LCD Television Logo
117 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
