Question about Verizon Communications G'zOne Type-V Cellular Phone
Judge You ended our chat. Are you coming back? Below was our chat: Hi. I am techexpert12 and I will be assisting you with your problem. techexpert12 says: hi JudgeGraham says: great techexpert12 says: tell me whats your problem sir. JudgeGraham says: Ibought a Verizon Blackberry 8830 on eBay and want to give to my MotherN Law, but she is on ATT wireless. How can I make the VerzionBlackberry work for her and still keeping her on ATT? techexpert12 says: it requires the code do you have the cproper code. JudgeGraham says: No I do not. What is a cproper code and how can I get one? techexpert12 says: sir the company blackberry is not disclosing the codes as the risk of it to be hacked by some expert hackers. JudgeGraham says: So does that mean getting this phone to work on ATT wireless is not possible? techexpert12 says: yes its very much possible. techexpert12 says: the company is providing these codes for free you just have to submit your unit to them for 24hrs and they will do it for you. techexpert12 says: by chance the technician can charge you the service charge. JudgeGraham says: What technician and who do I call? techexpert12 says: reply. techexpert12 says: from where have you got this unit. techexpert12 says: reply JudgeGraham says: I bought it from eBay techexpert12 says: do you have any bill for it. JudgeGraham says: Maybe it was a couple months back when I bought it techexpert12 says: contacting ebay is not of any use, but you can get the number of the service center of your unit from ebay. techexpert12 says: that may help. JudgeGraham says: Sorry I am not following on how you want me to call and how I can get this Verizon phone to work on ATT wireless JudgeGraham says: Would a service like this help? www.cellphoneunlock.net/ techexpert12 says: no sir this is just a link. techexpert12 says: hold a minite i will provide you the information. JudgeGraham says: Great thanks techexpert12 says: ok.
    Master:
  • 521 Answers
The server was down .so sorry for that.reply.
Posted on Aug 18, 2008
SOURCE:
Light come on and then shuts off after 115 seconds.
Difficult to judge from the symptoms but it could be waiting for water to be fed in. Try the following:-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
E 02
'E02' decodes as 'fill time-out (slow fill)'.
If you have checked that the water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking the water inlet filters. Turn the taps off and remove the water hoses at the washer end. Inside the inlet ports there are normally little filters which should just slide out. Clean if necessary and replace them and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning water control valve (hot or cold- difficult to judge without being there). Sorry but it needs replacing and a service call ;-0(
John C
May 07, 2011 | Hoover AAA140 Front Load Washer
Hi no chat available anymore..how come?
All are facing the problem with facebook recently. Wait for some time and check the same.
Revert back for more assistance.
Jan 28, 2010 | Facebook Social Network
I DID NOT PRINT SCREEN BEFORE ENDING SESSION SO ALL HELP HE GAVE ME IS LOST
Can I contact my Live Chat Expert after the chat session is over? You can correspond with your Live Chat Expert by posting a comment to the Chat Thread, located inside the My Problems section of your My Profile page. Click on the question you posted to access your chat transcript, and leave comments. The Live Chat expert will be able to view these comments. Where can I view the transcript of my Live Chat session? Your chat transcript can be located inside the My Problems section of your My Profile page. Click on your question to access your chat transcript.
Hope that would help you.
Any further assistance, let me know!!
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | Cell Phones
Retreiving initialized recordings on a canon DC310 camcorder?
Hi, Seems like you ended the chat before we had a chance to sort out the problem. Do you need further assistance? You can email me
Aug 08, 2009 | Cameras
Your offer
try and install the newest service pack, that will replace most of the windows files. if that doesn't work, you can use the extract command in the windows command console to extract the needed files from the windows cabinet files (*.cab) off the windows installation cd.
Sep 03, 2008 | Toshiba Satellite A100-S8111TD Notebook
Stuck start/cancel button
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0047_8.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 22, 2008 | Dryers
Remote Assistance
You know what I do.. If we solve the problem with remote assistance, I mostly take them back to fixya if already closed, then on the my profile page open the write a review link on the chat for them.
Yeah no problem.
Btw, I think it solved on its own I haven't changed anything but its only showing one email in all messages now instead of duplicates.
May 26, 2008 | Baby Gear
Verizon Communications G'zOne Type-V Cellular Phone Logo
88 people viewed this question
Top Verizon Communications Cell Phones Experts
RONALD CARTER JR
Ekse
Marvin
Marvin
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
