Question about Samsung Digimax S630 Digital Camera
Samsung S750 camera won't turn on
My camera just froze now it won't turn on the lens is still out
  • 1 more comment
  • summergirl25 Sep 11, 2008
    same. did you drop yours?
  • Anonymous Oct 05, 2008
    the exact same thing happened to me
  • Anonymous May 20, 2009
    i dropped mine and this happened. :(
Replace the battery & restart
Posted on Aug 19, 2008
SOURCE:
I have a Sony Cybershot DSC-S750. It will not turn off or on. The battery is full. It turned on earlier today and then suddenly just would not turn off or on. The lens is in the "on" position...
I have a similar Sony (DSC-L1) and have had the same problem. Remove the battery and SD card, vacuum (or blow on) the lens surround. Seems that grit has stuck between the lens and the cover.
If all else fails, try inserting the battery and gently pushing the lens the lens in. NOT guaranteed, but if this fails, try a photo dealer.
Mar 09, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
My camera DSC-S750,got knocked down while taking picture.The zoom does not go in and when i try to turn it on,a flash comes as if its on and then turns off automatically.Please help.
The shock gave it a mechanical problem. It is probably hitting an error sensor when trying to open/close the zoom lens and turning itself off to protect itself from further damage. It will need to be repaired.
Nov 30, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Over head spots when capturing pictures.Camera model is Samsung S750.
The lens has dust on or inside it and needs cleaning with a lint free cloth
Aug 01, 2010 | Samsung Digimax S750 Digital Camera
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
NV30 froze
Samsung NV30 turns on then beeps then turns off
Oct 29, 2008 | Samsung NV30 Digital Camera
Error 2111 on camera VPC-S750 when i try to zoom in it says lens error 2111 and shuts off. the lens does not close when i turn my camera off.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Samsung s750 digital camera instructions
I mistakenly deleted pictures. How to return them from recycle bin in my digital camera Samsung S750?
Jan 07, 2008 | Cameras
Samsung Digimax A7 Digital Camera Problem
My camera will not turn on , it froze last month whilst the lens was out so i pushed it back in and it started to work fine this time it has forze or broke with the lens inside and it will not turn on the batteries are fine but i cant turn the camera on?
Nov 05, 2007 | Samsung Digimax A7 Digital Camera
Samsung Digimax S630 Digital Camera Logo
306 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
