It says the cover is open and its not. - Televison & Video
  • 44 Answers
What cover is open? If you don't know look around and if there is a cover, open it to see if there is any switch inside. Make sure it the door contacts this switch. A good way to test this is if you see the switch inside and are able to activate it with your finger or pen, do it and see if the message goes away if it does you found the problem. the door isn't contacting the switch. try to close the door using flashlight making sure the door pushes the switch.
Posted on Aug 18, 2008
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Apr 24, 2009 | Office Equipment & Supplies
Motorola Z3 cover won't stay open
you juss need to get a new one! if it slides open that easy when you turn it upside down...then yea a new one needs to be suggested.
Nov 23, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
"Offline"
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Open cover
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cover open
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
