Question about Kitchen Ranges
Dcs stove igniter will not stop sparking igniter and control are dry nothing spilled on them
  • 1 more comment
  • Anonymous Aug 18, 2008
    range igniter will not shut off
  • c_sumner Sep 13, 2008
    I took everything apart and used my meter to attempt to troubleshoot this problem. It appears that the igniter is broken. My DCS grill uses an ELTEC igniter part number 18351. There's a web site that lists them for sale for $89.
    Charlie
    c_sumner@bellsouth.net
  • jcminier Dec 03, 2008
    I have a DCS 6 burner and the middle back can't stop clicking. what is the solution to this problem? easy fix?
Can i fix a ignitor myself 52 single
Posted on Feb 05, 2009
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Having serious problem with the ignite. When I turn it on and its lit the clicking of the spark does not stop. Also, one of ranges will not light at all! Help.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 09, 2010 | DCS RGS-305 Professional Gas Kitchen Range
New stove gas is flowin but electrodes wont ignite turn knob to high light with lighter and flame shoots out but dont stay on please help
  • Where starting is manual (there is a 'start' position on the control(s), a set of switch contacts on the control(s) provides power to the ignition module.
    • A problem of no spark with only one control indicates that the fault is with it or its wiring.
    • A problem with continuous sparking even with all the controls off or in their normal positions indicates a short - either due to a defective switch in one of the controls or contamination (e.g., spilled liquid) bypassing the switch contacts.
  • Where starting is automatic, an electronic sensor, thermocouple, or bimetal switch provides power to the ignition module as needed.
Before you blame the ignition module for either lack of spark or continuous spark, make sure the wiring is in good condition and completely dry and clean ( or reasonably clean). Confirm that proper voltage is reaching the module with a multimeter or neon test lamp. The modules are quite robust:
  • Any liquid that may have dripped into the module may result in temporary or permanent failure. Fortunately it may be possible to pop off the bottom cover (with power OFF or the module removed!) and clean it. The most likely failure would be the SCR if you are into component level repair. Else, just replace it.
  • WARNING: There are several capacitors inside that may be charged to as much as 300 volts. The charge they can hold is probably not dangerous but may be painful or startling. Discharge these before touching anything inside or attempting to check components. Use a screwdriver blade or test clips and then confirm that they are discharged with a multimeter.
  • Contamination of the controls from spilled liquid may result in continuous activation of the ignition module since any electrical leakage across the switch contacts will likely be enough to activate it. Remove the control panel cover and dry it out or unplug the range or oven for a couple of days. If the contamination is not just plain water, it is a good idea to clean it thoroughly to prevent future problems.
  • Spills into the area of the electrodes at the gas burner assembly may short out the ignition for ALL the burners since they probably use the same module. Again, clean and dry it out or let it dry out on its own (if just water).
These are solutions for standard modules and replacements should be available from your local appliance repair shop or parts supplier. An exact mechanical match is not needed as long as the specifications are compatible.
May 09, 2009 | Kitchen Ranges
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
832 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
