The magnetron is most likely the problem, it heats the food and is the heart of the of the microwave oven, if it was followed by unusual odor more noticeable when you open the door that would confirm it, but that is not always the case. The cost to repair would exceed the cost of a new one
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
This is a indicator the magnetron is going, take warm soapy water and wash until spotless, sometimes food particals will cause this, if no change! check interior for paint peeling and exposed metal, again a potential issue. If no change! the price of new one is worth considering due to attractive pricing.
Make sure the inside is clean of all grease and the paper like screen needs to be removed and cleaned also. If the screen is burned it needs to be replaced. You can find one at an appliance parts store.
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
The noise is probably from the high-voltage transformer. When it
is overloaded, the excess magnetic field it produces vibrates its wire
coils. Odd that it only happens for a brief time. It is
either defective itself (in which case it may go a long time) or it is
getting overloaded by the magnatron/capacitor/diode on its output (in
which case it will get worse shortly)
Hope Ya Fix it
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same.
Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open.
Take care and close the door properly before you leave kitchen..
