Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Tub continues to spin
During spin cycles if we open the lid the tub continues to spin. It also makes a loud thumping sound with each rotation. The agitator remains motionless.
  • pjjeffrey Aug 18, 2008
    Lid switch appears to work fine. The tub can be rotated by hand and makes a loud thump each rotation. How do you check to see if switch is stuck in closed position? Any other thoughts?
  • 770 Answers
Sounds like someone either wired out your lid switch or it is stuck in the closed position check that first
Posted on Aug 18, 2008
  • Gary Davd
    Gary Davd Aug 18, 2008
    well if you open the lid during spin and it still spins your lid sw is bad
SOURCE:
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Whirlpool ultimate careII spin cycle
sounds as if perhaps a wire is off on the side of the motor assy, l;ook at he wiring harness, sometimes a "chugging " noise occurs form the motor when one of the harnesses is not attached. and yes its normal to wash with the lid open, not to spin however( thats a saftey issue)
Jan 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Whirlpool top load washer
Check to be sure inner tub is not spinning freely on spin tube. It can be noisy when this happens. When it's spinning and stops it may continue spinning for a bit when this happens. You usually need to replace spin tube, because the tabs that key into drive block for inner tub break off. Also replace drive block.
Nov 08, 2007 | Washing Machines
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
89 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
