Question about Lexmark Office Equipment & Supplies
I have windows vista and i can't find how to download software. Directions say to cancel out of found new software screen and nothing esle comes up.
    Genius:
  • 1,689 Answers
You may want to check on Lexmark and Vista's compatibility list, if your printer is in the list you will be able to download and us ethe drivers, if not, my apologies but the pritner may not be compatible with Vista.
Lexmark and Vista Comatibility List.
Posted on Aug 18, 2008
SOURCE:
I am having trouble connecting my lexmark printer a my vista laptop. I do not have the cd anymore so please help me if there is a way?
Lexmark has the drivers and full software for supported OS versions on their site: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X1270&focusedTab=DOWNLOADS#1 . Select your version of Vista (32- or 64-bit) and then click Filter.
Click on the link and the download page should pop up. Click on Download at the bottom of the pop-up window.
If you allowed the Add New Hardware wizard to search for the drivers, disconnect the data cable and then uninstall any driver that was found. Restart your computer. Reconnect the data cable and cancel all Add New Hardware screens that open. Then run the exe that you downloaded from Lexmark.
I hope this helps.
(Note: the download probably doesn't include third-party software that may have been on the original CD.)
Aug 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
P1005 hp printer windows vista will not recognise
hmmmm i would first make sure all window vista driver are in first. then try installing the cd. or if you want to try the driver only and not all the extra software...
1st uninstall the driver and software and do not connect the printer. until it asks you.
2nd put the factory cd for the printer but do not let it run automatically. cancel the installation.
3 you go to the control panel add printer, etc. have look for the driver and say "have cd" or go to the cd drive where the vista folder is holding the driver file.
i know this can be tidious but its kinda old school for installing a driver instead of letting the cd do it automatically have the computer find the driver on the cd first. dont add all the extra software. try it and see if it works then try to add all the extra software.
personaly i think sometimes the vista updates stuff where it screws with the drivers and then your computer does not know what its looking for. i hope this kinda helps. sorry for your mishap.
have you also tried connecting to all the usb slots?
Apr 21, 2010 | HP LASERJET P1005 Printer
My Laptop won't register new devices
This is just a software issue. There might be uncompatible software installed in your computer or malware. 1st thing try to disable your computer's start up (remove all the driver software you installed for new devices) then restart your computer.
2. Connect 1 device then install the driver.
** if still not working need to perform windows system restore. You can choose the desired restore point or the last time you were able to use your computer normally.
procedure: vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
**If still not working, you need to perform Factory recovery or set everything back to factory default. or use the recovery disk.
Note: before doing any Troubleshooting in your make sure that you have back up for your important files or image for the programs that you have.
Mar 30, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
Is this not compatible with vista>:
Yes, there is a Vista driver available for your printer.
Go to:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Enter your model # in the Search by Model box. When the gray model number appears, click on it.
You will then be take to a page to select your operating system. Select Vista.
(Note: There are 2 types of Vista...32 bit and 64 bit. You need to select the proper one. To verify what you have: Right click on the Computer icon on your Desktop and select Properties. A window will open and it will say 64-bit in the window if it is. If it doesn't say 64-bit you will select
Vista. If it is 64-bit you will select Vista x64)
Once you select your OS, you will be taken to another page to download the driver. Click on Download Now.
Save the file to your Desktop. When the download is complete, make sure all other printer software is uninstalled. Turn your printer ON. Connect the USB cable. If your get a New Hardware Found window, cancel it out. Then Run (double-click) the file you downloaded on the Desktop.
Thanks for using Fixya.
Aug 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
When I bought camera I had Windows XP. New computer has Vista.
So you now have Vista, but the software will not load...
If you have Windows Vista (32-bit), click this link and download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1154651&lang=en
If you have Vista 64-bit, use this link. Download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&product=1154651&lang=en
I hope this helps you, don't forget the "FixYa" rating if this solves your questions!
Apr 03, 2009 | HP Photosmart R725 Digital Camera
Finepix z20fd
I have Windows Vista also, but my installation screen came up. If nothing pops up when you put it in, I would suggest opening "My Computer" and right clicking the icon with FinePix and starting it that way. Or, maybe you could check the Fujifilm site and see if you can download the software off the internet.
Dec 31, 2008 | Fuji Finepix Z20fd Digital Camera
Unable to install printer
Step one: Determine the appropriate compatible driver
Since there is no driver for the deskjet 656, the hp site says the alternative driver would be for the deskjet 660c. There is no need to download it as it comes with Vista, but we will need to install and configure it.
Here are some directions:
Step two: Install the driver
1. Verify that the Universal Serial Bus (USB) cable is not connected to the printer.
2. Click the Windows icon ( start ), click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6.In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (in your case, the 660c) , and then click Next .
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of your printer, if desired.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Step three: Configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB
4. Click Apply .
Step four: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Dec 15, 2008 | HP DeskJet 656c InkJet Printer
How to get scanner working
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Photosmart Software and Drivers: USB Support
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Full Feature Software and Drivers
On the next page, scroll down to "download only"
Click on the button.
In order to get the scanner drivers you need the large package install from www.hp.com. Above are the links for windows xp and windows vista scanner software.
Feb 13, 2008 | HP Deskjet F340 All-In-One Printer
Open Questions:
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
