Question about Frigidaire ATF6000ES Front Load Washer
Tumble action front load washer
The washer goes all the way through the cycle and spins and everything at the end of the cycle the water doesn't drain and the clothes are still soaking wet. All the lights stay on after why is that? Anybody know?
  • 3 Answers
Going to take a little surgery. Most likely a small sock or other article made its way down the drain pipe and clogged against the pump.
I have a Frigidaire Gallery Series front load washer. I've had to do the following at least six times in the last year and a half. Each and every time, it was an errant sock from my three year old.
First, unload all the wet clothes into a garbage bag. Then **** out all the water using a wet/dry vac. You need to do this for safety reasons because you're going to be tipping the washing machine back and having water slosh around could cause it to fall on you.
Once you've sucked out as much as you can, pull the washing machine out from the wall by about three feet. Then with the help of someone, tip it backwards so that it rests against the wall. Have your friend hold it in place.
At the bottom on the front are two screws holding a panel on. Remove those to gain access to the guts.
If you look to your right side you'll find a pliable rubber boot mated to a hard plastic pump. Using a pair of channel locks or other suitable pliers, squeeze the wire clamp down and pull towards yourself. Be prepared for some water spillage when it comes off. I usually put some towels under the pump area and then use the wet/dry vac to **** the rest of the water out of the rubber grommet area.
Once this is off, you'll most likely find something clogging up the pump (the hard plastic part). Pull that out and essentially reverse your actions up to this point to put it back together. I will warn you it takes some patience to get the pliable rubber boot and clamp back in place on the pump inlet. Sometimes it takes me four or five attempts and I've done this a few times already. The key is to make sure you've made a good seal and the wire clamp is holding securely.
If you bought the under washer/dryer storage boxes, you might be able to get away without tipping it back, but I don't know for sure. The important thing is to try and get as much water out as possible.
Good luck.
Posted on Aug 18, 2008
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
