Question about EliteGroup P6IWP-Fe Motherboard
KEYBOARD WHEN I TURN ON MY PC THE KEYBOARD JUST FLASHING AFTER I CAN´T USE IT
    Scholar:
  • 119 Answers
If you are using a USB keybord then you will have to change the settings in your bios setup so as to enable USB support, thus you will be able to use you usb keyboard and usb mouse, but you will obviously need a ps/2 keyboard in order to access the bios setup and make the necessary changes. On the other hand if you are already using a ps/2 keyboard the problem could be the keboard, so try another one if that does not work then you keyboard slot could be damaged (try a usb keyboard - with any luck the usb interface would already have been enabled but you can also enable it within your operating system just using your mouse. Also check with your ps/2 keyboard that you are pluging is in the correct slot (purple- keyboard, green- mouse)
Posted on Oct 17, 2008
Why is keyboard not responding?
This answer relates to keyboard hardware issue only.
On powering on PC look for keyboard lights flashing.
If no flash. Power down. Remove/replace kbd plug.
If still no flash of lights then please read on.
If kbd is old ps/2 type. Which is small round, sometimes purple, plug.
Ensure its not in not in the similar mouse socket.
Check for bent pin in plug.
ps/2 sockets can fail (as can keyboards)
If no joy and no other ps/2 keyboard works, consider replacing with usb type.
If kbd is usb type, do power off/on look for lights flashing.
If no flash of lights, try in different usb port.
Try replacing keyboard.
Hope this helps.
Jul 24, 2015 | Dell Inspiron Computers & Internet
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
My compaq evo d510 cmt keyboard lights flashing constantly
first problem its a compaq go buy something else no seriously buy something else
check your bios settings F10 for compaq if i remember corectly might be F2
http://h18000.www1.hp.com/products/quickspecs/11349_na/11349_na.HTML
http://reviews.cnet.com/desktops/hp-compaq-evo-d510/1707-3118_7-20719364.html
i mean com on 533 bus and dosnt saport multi core cpu's
my 2004 dell 200 mhz buss saports quad core wth
if its not a bios setting replace your keyboard good luck
Feb 19, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Mouse is recognised but key board is not.
Normal 0 Press the Receiver button (and the lights will start flashing.
Turn the Keyboard over and press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver. Should work okay then.
Hope this helps. Bud
Feb 18, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Pc wont always turn on and keyboard and mouse wont always work
Sounds like your OS has had some vital system files deleted. you may need to reinstall your OS.
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
PC not recognizing monitors or keyboard
Try flashing the bios, which is found as step 3 on the flowing website. here.
If that does not work, make sure the connectors are not damaged, and ensure that all internal components, especially power cables, are properly seated.
~gnome
Jan 04, 2009 | HP Compaq Presario SR2150NX PC Desktop
Problem with the receiver on my wireless keyboard & mouse KB985W
If you still have the software that came with your keyboard and mouse then i suggest you reload it, it appears that some of your keys have functions to them and they are misbehaving.
If you do not have the software then remove the reciever from the computer and then replace it again. press the connect button on the reciever then the connect button on the keyboard, wait for it to register the keyboard then press the connect button on the reciever then the connect button on the mouse and wait for it to register.
Hopefully this will help.
Nov 16, 2008 | Micro Innovations PD7250LSR Wireless RF...
Mouse and Keyboard not recognized
i think ur computer hangup after booting
there may be some problum in ur op system . it hase virous.
2nd u test ur mouse and keyboard to another computer if they work correctly u have to reinstall ur op sys
u can call me 91-9329204658 india
Jun 01, 2008 | E-Machines eMachines Desktop PC
Emachine t2385
You might have a stuck key on your keyboard. I emphasize might.
Try this though:
Remove the power cord from the back of your PC. Leave it out for a minute or so. While it is unplugged turn your keyboard over and strike the top of the keyboard against your work area top a couple of times. Some debris may come out, could unstick any key that may be stuck. Reattach the power cord and if it doesn't power up immediately turn the power on and see if everything is okay or not.
If not, let me know by commenting back so I can talk you through another troubleshooting technique. Okay?
Regards,
Worldvet
May 24, 2008 | E-Machines eMachines Desktop PC
EliteGroup P6IWP-Fe Motherboard Logo
115 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
