Question about Electrolux Epic 6500 Vacuum
Warning Light What does the light mean on the canister that has two prongs on one end and one on the other. The vacuum works fine but the light is on. I changed the bag and filter.
  • sd654321 Sep 08, 2008
    With a new bag and new filter was installed,the vacuum has good suction but quickly shuts itself off and illuminates the full bag warning light.
    President:
  • 1,673 Answers
Check the hose and wands for a clog. Usually that light means a full bag, but a clog or restriction will also cause it to come on.
Posted on Sep 01, 2008
My magic Blue vacuum is turning off and on when the hose ifs moved I think
I would recommend checking where the end of the hose attaches to. On Kenmore vacuums where the end of the hose plugs into the vacuum and to the powerhead there is normally two prongs that plug in to the canister and the power head. It is either one of the ends that is not connecting right especially if you say when the hose is moved. It may also be the cord inside the hose that connects to those prongs might be torn inside the hose or not connecting right to each end.
Jul 18, 2012 | Kenmore Magic Blue 24195 Bagged Canister...
Warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
Kenmore progressive canister bad connection from hose to canister
It could be, the female part of the connector is stretched open. You can usually insert something, like a dart, between the sleeve and the holder, to tighten it. If you paid with Pay Pal, see about getting your money back.
Jul 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
The red light on my hayden 3600 vacuum won't go off
I have a 6000 and it does the same thing. I simply unplug the unit and plug it back in after cleaning the filter and dumping the cannister. That seems to reset the warning system.
Jul 06, 2009 | Hayden Industries SuperVac 6000 Central...
Warning light
make sure the bag is not full
May 18, 2009 | Miele S318 Bagged Canister Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 21875
Give the prongs a wiggle and see if there is any play in them.Might just be a plug end.
Oct 18, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Powerhead does not work and the light doesn't work. Canister does work
Some of these has a reset button to push on the powerhead. Check the plug at the end of the hose handle, is it pushed in, if you push on it and it goes further in, then the tube in the handle will have to be replaced, the holding tab broke off of the tube. Pull the wand off and look at the prongs to see if they are burnt. it they are, then that power cord will have to replace as well as the want.
Jan 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
370 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
