It is suppose to shut off but should turn back on. If it's working properly but the indicator light does not come then it is a bad indicator light.
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
A replacement plug can be purchased at a hardware store.
I think I understand what you are saying: The A/C unit operates for a period of time, then the plug switches itself off and you need to push the reset button on the plug to turn the unit on again. If this is the case, then there may be a problem with the A/C unit. Make sure that the water which the A/C unit produces (condensate) is capable of leaving the unit (dripping through holes to the outside). If I could not find any reason why the unit should be shorting out internally, and it was my unit, then, against ALL safety standards, I would put a regular plug on it. It it was for a customer, I would test it through another GFI.
Where can I get a replacement plug?
The unit never powered off before. The unit would stay on as long as it was powered on. Since the power light isn't working, now it powers off and stays off.
