Ricoh Aficio 650
How to network?
  • 162 Answers
· No toner collection bottle
· Toner collection bottle switch defective.
The Switch is underneath the discharge sewer. In order to replace it is necessary to remove the motor, but sometimes the handle is overcome and by this the bottle does not get to drive it.
Posted on Sep 02, 2009
I have a Richo Aficio 650 copier and get a error of CS496-00 does anyone know what this means?
Posted on Sep 12, 2008
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
My copier is ricoh aficio 650 during it self test and worming time the message appear sc101 - 00
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
May 13, 2011 | Ricoh Aficio 450 Copier
Use ricoh aficio 220 as network printer
If you have the print/scan option installed on the copier, just to go the Ricoh website and download the print driver, and you can use it as a network printer.
Feb 23, 2010 | Ricoh Aficio 220 Laser Printer
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
363 people viewed this question
jasbo
jasbo
