To fix your horn is easy, there are some excellent pills out there.
The bikes horn though is different, you will need a small test light or multy meter,
Check if there is power to the wire plugged onto the horn, ignition on
The horn needs direct power to one terminal, and the other terminal shorts to earth through the button.
If there is power and the other wire connects to earth, when the button is pressed you probably need a new horn( not that expensive)
If there is no power check the fuse
If the second wire doesnt connect to earth when the button pressed there may be a problem in the handle switch.
There can also be a problem in the wiring if it has been damaged in the steering stop etc
Sometimes the horn can just be stuck and a small tap on the horn with the button pressed can start it.
If the horn button it a bit corroded in the contacts, hold it in and wiggle it a bit, can clear the corrosion.
Sometime easier to just check the fuse then buy a new horn, before chasing down the wires and switches
Testimonial: "Thanks a million, I got the pills, they really work, I wonder can you overdose? ;) As for the bike, I'll check out all that you mentioned, thanks"
