Question about Dell Latitude D600 Notebook
Periodic Boot-up Problems with Dell Latitude D600
My Latitude D600 is 4 years old and has taken a few hits. In the last two months, it's had boot up problems. About 75% of the time, when I hit the power button to boot it up, the power button light and the battery light at the hinge to the lower right of the screen will light for a few seconds and then go blank and the machine will not boot. Repeated efforts, including holding down the power button for 5-10 seconds, yield the same result.This happens both when the machine's power adapter is plugged in and when it is not plugged in and running off of a charged battery. I can try turning it on 5-6 times in the course of 15 minutes to no avail, and then return 1 hour later and it will work without explanation. The battery seems to work because on the occasions that the machine does boot and the batter is charged, it will work fine without the power adapter.
When it does boot up, it takes noticeably longer--maybe 2-3 times as long--for Windows XP to boot up than it did for years when the machine worked fine. This is separate problem that my intuition says is related to the first problem.
Any help would be appreciated.
  • 1 more comment
  • ottewitte Aug 21, 2008
    Symptoms I have encountered with two out of about 20 of these notebooks are virtually the same, with the exception that I don't recall them being slow to boot up when they do work. We have tried multiple batteries and AC adapters, to no avail. Because we have other D600s, we have been able to include batteries that are fully charged as well as those partially charged. I did notice that the two bad boys each have a pair of 512 Ram sticks in them, unlike any of the other machines that do work. I will experiment with that fact as well as follow the suggested solution posted here.
  • ttheus35 Jan 12, 2009
    I have this problem with my Dell. When I try to start my Dell D600 which I bought about a year ago. The power button is pushed and then the middle button next to the power with the "A:" blinks about 10 times without the computer booting up. Then when it does boot up. I can be working on it and it will freeze. Oh on other times it might just shut off like someone just shut off the power. I have replaced the fan and have blown it out. I don't dare move it while working on it. It will freeze then too. Please help.
  • Anonymous May 19, 2009
    I have the same problem. If you press on the back of the laptop around where the fan is then it will boot. I took mine apart looking for something but could not find anything.
Well I had the same problem with my Dell Latitude D600. I tried many batteries, fully charged, partially charged and even i tried scenarios with AC Power On or Off. Nothing really seemed to work as my laptop was both hot and cold. I noticed this problem was coming specially when laptop is cold.
The Solution is found is, when i have this problem, i press the power button and then move the rotate the laptop, so that its screen touches the desk and keybord is upright verticle, i know it sounds ODD, but it really made my life so easier as now this problem doesnt haunt me.  and it will boot on first, second or third go.
Normal Laptop Condition with keybord down and LCD Open
                     /                     /      / lcd
__________/
You need to move the laptop in one of the following if it is having boot problem again
       \               /          \            /            \         /  keybrd  \      /  lcd                \   /                 \/
or put the lcd down flat while keeping the keyboard in the same position as above.
I m sorry the above illustrations are pretty rough but hope u understand what i mean :)
Posted on Dec 13, 2008
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
  • 48 Answers
Ok, I think you are having overheating problem.
Make sure you fan runs it is critical component especially in a laptop. If your computer takes a long time to boot like that and runs slow in windows than normal and you know it is not a virus problem or software issue than it is most likely a thermal problem. Open and make sure the heat sync is not clogged as well. Stick a flashlight through the side where the fan blows out air and if you cannot see through or see the heat sync fins than you have too much dust also. Good luck.
Posted on Aug 18, 2008
Why does my boot keep tearing, original lasted years, all replacements are months.
had this once before
A wire from an under wire bra found its way in-between the inner and outer drum
every now and again it would find its way to the seal and tear it
then one day the drum started making a loud grinding sound
on further investigation we found the wire
that fixed both problems
Nov 11, 2017 | Bosch Nexxt 500 WFMC3301 Front Load Washer
UNMOUNTABLE BOOT VOLUME
This is most likely due to a HDD failure, Try to boot the computer off a windows disc and try to get to the command prompt through the recovery utility. Once you have a command prompt if possible, type in chkdsk /r hit enter. If you cannot get this far, try uninstalling the hard drive, remove battery, work off the ac adapter only and reinstall the HDD and try to boot it up, if it boots, turn off, reinstall the battery and reboot, hit F8 and choose "last known good configuration".
Jan 07, 2010 | Dell Latitude D810 PC Notebook
Dell Latitude D600 Boot problem
Weak battery, bad power supply adapter cable, and/or a dirty power switch can cause this problem.
Sep 19, 2009 | Computers & Internet
Right arrow key writes n- bbb n- n- etc.
Run the 32-bit diagnostics test on your dell computer:
1. Shutdown the system
2. Press and hold "Fn" then turn it on (while holding "Fn")
3. The Pre-boot Self Assessment would run
4. Just follow the steps on the screen
5. When memory test is done just continue
6. Select "Test System" when prompted
7. It will boot to Dell Diagnostics
8. Choose Custom Test
9. Run the keyboard test and follow screen instructions.
10. If the test fails, replace the keyboard.
11. If it passes, reinstall Windows.
Nov 25, 2008 | Dell Latitude D600 Notebook
Dell Latitude won't boot up and reinstalling Windows XP is taking forever
well it could be a bad sector on the hardrive .. couple of questions did you reformat the drive you are installing it in? Did it give you that option on your reinstall?
Sep 21, 2008 | Dell Latitude D600 Notebook
Wont boot
for no boot issues, you can try accessing windows advanced boot options by hitting F8 as soon as you see the dell splash screen. try to boot to safe mode or last known good configuration. if it doesn't work, last resort is to reformat the computer.
i hope this info helps.
Sep 04, 2008 | Dell Latitude D600 Notebook
Dell latitude D600 booting problem
Are all three lights on when you hit the power button?
Aug 25, 2008 | Dell Latitude D600 Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
DELL Latitude D510
unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
"You can boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows"
Nov 19, 2007 | Dell Latitude D510 Notebook
Dell Latitude D600 Notebook Logo
834 people viewed this question
Alun Cox
