Question about Tomtom GO 300 GPS Receiver
Green Light / Dead Tomtom - Please help with component id
I have accidentally plugged a 12v supply into my tomtom 500 ( which I think is basically the same component wise as the 300 ) and blown it up.
I know through reading posts on this forum that I am not the first idiot to do this. The unit is dead apart from the green light, on inspecting the panel U24 is burnt although U25 and the board print seem ok. My problem is identifying a surface mount component which got completely burnt up.
see pic
as you can see from the picture I have removed the component which I believe to be a diode. If anybody knows the value of the component and the number of a possible replacement I would be very grateful. I am led to believe that a 1N414n might be suitable but have been unable to obtain one.
If it is a diode I would also like to know which end the anode is soldered onto, as I say any info on the component would be great.
Many Thanks
Tony
    Novelist:
  • 158 Answers
That diode is a reverse polarity protection diode. An 1N414 will do ( available for very very little from almost ALL electronic component suppliers.) If there is NOTHING ELSE WRONG then the tomtom will still work without this diode. Its not needed in normal operation anyway. All it does is cause the fuse to blow in the cigarette lighter plug if the polarity is accidently reversed. Therefore , with a correct supply , it does nothing !
Posted on Sep 13, 2008
Tomtom still charges but traffic receiver stopped working
I'm using the TomTom Go 730T - I think this is the latest and the last TT with Traffic because TT stopped supplying this option. I'm having the same problem from time to time but a reset helps. Just press the Reset button and after restarting the traffic option is back. Janos
Jul 09, 2010 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
My tomtom go
hello, this problem and answers is covered under the TomTom Go 300 section. Please take a look there to get an answer. Its very comprehensive.
Sep 11, 2008 | Tomtom GO 700 GPS Receiver
TomTom one dead
then you have a nice paperwieght!
Sep 01, 2008 | Tomtom ONE GPS Receiver
Tomtom one not poweringup
Lofty same just happened to me, following great deal of searching, my conclusion is that over voltage has fried regulator chip in tomtom, the reason you have green light is because at different part of power board. Approx repair cost if damage is not too bad (50% cannot be repaired) is £70.
TOMTOM will have a look for nothing, and give you a quote, if don;t want to proceed they will send it back for free also.
Good luck.
Mar 17, 2008 | Tomtom ONE GPS Receiver
CANNOT RECHARGE TOMTOM
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Feb 16, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom 300
Have you tried resetting the unit?
small pointy object in the hole marked 'reset.'
failing that...
http://www.tomtom.com/support/index.php?Lid=1
Sep 01, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
1,420 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
