Vscan for philips 42 in plasma
I have a philips 42 plasma 42pf7321d/37 that I updated the firmware to remove the 4 blinking red led light. Now I don't have that problem but get 3 blinking led on power board. The sig alarm says for 3 it is the vscan. Another expert here on FixYa said to unplug the cable and if power stays on, then that is the problem. Well, power does stay on now so what do I need to do? Is there anything else I need to check or would changing the y sus main board fix this problem and also do I need to change the other 2 cards to the left of this card? Finally if I can change and do it myself, I am having a problem locating boards that have this same number so how important is it that the part number be the same or what is compatible with a pdp module that is S42AX-YD01 ( Power board is LJ44-00101CPS-424-PH Rev 0.7. (Dont know if that matters but I figure give you more info than not enough. I hope you can help)
  • 52 Answers
I would recommend replacing y main and y upper and lower buffer boards based off your troubleshooting as they complete circuit. these samsung boards have an lj92 number on them that will cross to part number. if you find an lj41 number that number is vendor number for circuit board prior to components being placed on board. hope this helps. dan
Posted on Aug 21, 2008
When I power on my 42PF7321D/37 Philips Plasma TV the green LED comes on then turne into a flashing red LED. Flashes 4 times then space then four times. TV will not turn on.
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout........
Aug 03, 2010 | Philips 42PF7321 42 in. Plasma HDTV
I have a 42PF7321D/37. power lite blinks 4 times and repeats. no picture
You need to replace the caps on the PSB-Power supply board
Best regards and Semper Fi
Aug 03, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
42PF7321D/37 LED Light Blinking RED
my dad had this happen too. after some research, we found out that there are two capacitors on the power supply board right next to the connector for the main logic board that went bad. you can just pull those out and solder in new ones, and it works like new again! i found a repair kit on ebay for $35 including shipping, and that's all it took!
Jul 17, 2008 | Televison & Video
Televison & Video Logo
1,501 people viewed this question
Top Televison & Video Experts
Electro Med Services...
