Question about Car Audio & Video
Radio Code Trying to obtain Code for Model No:39100-SW5-A1000 Serial No. 94A609750. No luck on checking fuse panel, glove box, and under coin tray. Help would be greatly appreciated!
  • 1 more comment
  • Bryan76 Aug 18, 2008
    1998 Acura 3.2TL
  • travisbaptis Jan 01, 2009
    dont know how to put the code in my kenwood kdc-x769
    i dont have a drivers manual and don know my code
    Problem Solver:
  • 37 Answers
Check your drivers manual.
Posted on Aug 19, 2008
Can i obtain the unlock code for my honda radio if i replaced it with another radio from a junkyard? ref no. CH-EH1060A MODEL NO. 39100-S84-A300 SERIAL NO. 10022597
please help Code for a Radio/CD in my Honda Element. Here's the info: P/N: 39101-SCV-A120-M1 REF.No: MF825A0 Serial No: GDZ2702421
Jan 23, 2015 | Honda Cars & Trucks
Need radio code for 02 honda crv, serial #13028929
The reset code for the factory installed radio is on a sticker in the glove box. The sticker has 2 set of numbers. The number set with 5 digits is the reset code for your factory installed radio.
Jul 09, 2010 | 2002 Honda CR-V
Replace fuse for radio
if you look in your owners manual in the glove box it will tell you where the fuse box is located and what each fuse feeds,
Jan 21, 2010 | 2002 Toyota Camry
Need radio code for 2007 honda accord serial #12367949, had to disconnect battery to replace head lamp
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio (some people say that they find the code on a sticker in the glove compartment, but I wouldn't count on that). Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release. The number will come up in two sets)
Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Hope this helps you.
Nov 16, 2009 | 2007 Honda Accord Sedan
Radio Code for my car 1998 Acura
You have to do this: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
Mar 27, 2009 | 1998 Acura TL
Honda CRV 2005 asking for radio code
hi!
well check for the radio code as in following steps:
1:Under the Hood of the Car is a Fuse-Box. (Different Fuse-Box than Inside the Car) This Fuse-Box has a Lid. Under this Lid is the Radio Code. Therefore, lift the Lid off Completely and the Code is underside of this Lid.
Look in your glove box for a white sticker with black numbers on it. The sticker will be about 1 1/2 inches long and 1/2 in wide. There should be 5 digits on it. These 5 wonderful numbers are your radio code. Put the code in through the preset buttons on the radio. You'll hear a beep and the radio will come back to life. (though you'll have to reprogram all your presets)
2. Ok, there's a sticker there, but there's more than 5 numbers on it! What do I do with that? Don't worry, that's the serial number for the audio unit. Call a dealer, tell them what happened and that you have the serial number and they can get the code for you for free. Write the code down and stick it in the glove box. Follow the steps in #1 above.
3. There's no sticker in my glove box, what now smart guy? Don't panic if you don't find a sticker, there are other places it's put sometimes. Check your sunglass holder (applicable models), the center console, even under the arm rest. I've even seen them under the cover of the under-hood fuse box. Check all these places and hope that u will find ur radio code!! good luck!
Dec 28, 2008 | Car Audio & Video
97 acura cl radio code
I had same problem with my 97 Acura 3.0cl and i called the Honda dealer they will ask your serial, Vin, model and milage # and then they will give u the code.
Nov 30, 2008 | 1997 Acura CL
I need a radio lock code for my radio on my 2001 Honda Accord Model# 39100-S82-A300 REF. No. CQ-EH1063Z SERIAL NO. 11124436
The code normally comes on a separate document as does key codes or numbers. You could check the owner's manual to see if it was noted in there. (A bad idea.) Also check for a sticker inside your glove box. If that doesn't work then you need to remove the radio/CD player from the dash to get it's serial number from the back of it. Take that number with your VIN to a Honda dealer and they should be able to get your security code for you. They will likely ask for your driver's license & registration to prove you own the vehicle.
Jul 31, 2008 | Honda Accord Cars & Trucks
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
