Question about Cameras
I have a Finepix A370 digital camera. Every time I take a picture the camera closes. When I change the batteries, it works for a few pictures then starts doing it again. It is almost like it won't keep the battery charge.
  • reemarson Aug 18, 2008
    I do not have the time or patience for rechargeable batteries. Anyway if it only takes 2 pictures and then I have to change the batteries, that it not really a solution to this problem.
    What are ni-mah batteries? Don't think this is a good enough solution yet.
    Master:
  • 638 Answers
It is the problem of bad sensors which detect the baterries.when you insert the new battery it pulls all the charge from your battery.no rechargeble batteries.just clean the metal sensors manully from inside and out side.if still the problem get it repaired at any repair shop it will cost you not more then 3$ including servicing.
rustness between the sensors always create this problem. do not worry it will be ok.
Posted on Aug 18, 2008
    Genius:
  • 1,689 Answers
A possible blown capacitor, or a leaking one may have caused this issue you are having, because it is very unlikely that a charged battery will give out just 2 shots. if you still have the camera warranty, please consult the manufacturer to have it checked before doing any physical troubleshooting with the unit.
Ni-Mh is Nickel Metal-Hyd if im not mistaken
  • 928 Answers
A nickel-metal hydride battery, abbreviated NiMH, is a type of rechargeable battery similar to a nickel-cadmium (NiCd) battery but using a hydrogen-absorbing alloy for the negative electrode instead of cadmium
This type of batter holds more charge than a regular battery and is rechargeable. Since it would be too expensive as a disposable type.
  • Thomas Lim
    Thomas Lim Aug 18, 2008
    Also, if you use batteries that are not designed for digital cameras they will not work as they do not hold enough charge to give the camera enough power which is why you loose the charge after only 2 shots. Make sure you ask the vendor where you buy batteries to give you some that are specifically designed for digital cameras
    Master:
  • 623 Answers
Try to use ni-mh batteries...or read the manual for a more compatible battery type...
    Master:
  • 521 Answers
Try using chargeble batteries.they are the best option for this problem.thanks.
DOWNLOAD PICTURES TO P C
use the data cable and software that came with your camera to connect it to a pc, or use a card reader to access the memory card of your camera to a pc to transfer/copy the pictures
Feb 20, 2011 | Fuji Finepix A370 Digital Camera
I went to a party, and i dropped my digital camera ! please help!
You most likely cracked and damaged the LCD. Digital camera's LCD repair sometimes cost almost as much as the camera itself, by the time you add shipping and other charges.
You can still take the pictures, but you will not be able to review them.
Dec 21, 2009 | Fuji Finepix A370 Digital Camera
I have a fujifilm a370 camera with a xd picture
use the "format" setting in the camera to initialize the card. it is in the "set-up" menu.
Mar 26, 2009 | Fuji FinePix F10 Digital Camera
Can not copy/ transfer images from Fuji FinePix A370 to PC
Remove the camera's software and reinstall. If this fails to solve the problem, use a memory card reader to transfer images from the card.
Feb 06, 2009 | Fuji Finepix A370 Digital Camera
Finepixa370 to vista
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require an update which can be downloaded from Fuji's global website
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
If you have other questions just let me know
Oct 04, 2008 | Fuji Finepix A370 Digital Camera
Have no cd rom for a370
Please can you help me i need to download pics from my a370 fuji camera and i have no cd rom or programme to save pictures to my computer. Where can i get the necessary downloads preferably free,
many thanks,
Richard.
Jan 22, 2008 | Fuji Finepix A370 Digital Camera
Fuji digital camera A370 lens sticking
It seems the life of digital cameras are 2-3 years. The camera has lens gear problem. The lens assy fails most on digital cameras with moving lens. The plastic gears in the lens assy. are quite fragile in design and when used regularly, gears tends to wear down and eventually damages the lens movement. Many time a small impact or stress on lens when extended do the same damage. The parts are sold as a lens assy and repair cost may run around $100.
Mar 18, 2007 | Fuji Finepix A370 Digital Camera
My fuji finepix a370 digital camera will only take videos now
If you have had it less than a year try returning it to seller as defective.
Jan 15, 2007 | Fuji Finepix A370 Digital Camera
Cameras Logo
60 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
