Question about Symbol MC50 Pocket PC
Install "CAB" Files into Symbol MC50 PPC
Trying to install CAB file for "Guitar Hero" onto PPC, but "clicking" just opens properties. Cannot figure out how else to install.
  • Anonymous Nov 25, 2008
    dunno dude
  • jphswf May 11, 2010
    Are you clicking from the PC or on the MC50 through file explorer? In a standard setup clicking on a cab file from file explorer on an MC50 should run through the install.
2 Suggested Answers
  • 3 Answers
SOURCE: MC50
It seems very easy but here is the users manual
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6819502apdf&sliceId=&dialogID=35606078&stateId=1%200%2035594914
Posted on Dec 28, 2007
Detailed instructions for extract and open guitar hero 3 torrent
download winrar from here http://rarlab.com/rar/wrar400.exe install it then open the directory where the torrent is located then right click on one of the files and click extract to xxxxxxx(the name of the file) in that folder will be, hopefully , your iso
Apr 09, 2011 | Video Game Consoles & Games
Tip
Cannot install a device driver by using its installation program in Windows...
ISSUE- You cannot install a device driver by using its installation program in Windows Vista
OVERVIEW-
When you try to install a device driver by using its installation program in Windows Vista, you are unsuccessful.
SYMPTOMS:
You may experience this issue if the following conditions are true:
• The driver uses an executable file-based installation program.
• The installation program was not designed for Windows Vista.
CAUSES:
Problems with executable file-based installation programs may occur if any one or more of the following conditions are true:
• The installation program is incompatible with Windows Vista.
• The driver is incompatible with Windows Vista.
• An issue occurs that is related to the user rights that are required to install the driver.
RESOLUTION:
To resolve this problem, run the driver installation program in compatibility mode. Or, use an account that has administrative credentials to run the driver installation program. You can also locate the .inf file for the driver, and then manually install the driver.
Important Before you use one of these methods, we recommend that you contact the device manufacturer or the driver manufacturer for more information about how to install the driver in Windows Vista.
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
To run the driver installation program by using administrative credentials
Configure the driver installation program to run in the context of the Administrator account. To do this, follow these steps:
2. Right-click the file, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
3. Follow the steps to install the driver.
To locate the .inf file and manually install the driver
Use Device Manager to install the driver. To do this, follow these steps.
Step 1: Locate the .inf file
Locate the .inf file that is included with the driver installation program. Generally, the .inf file is located in one of the following folders on the driver installation media:
• In the same folder as the Setup program.
• In a subfolder that is in the folder that contains the Setup program. Generally, the subfolder has a name such as Windows XP, Drivers, or WinXP.
If the driver files are packaged in a single executable file, you may be able to extract them or otherwise access them. To do this, use one of the following methods, as appropriate for your situation:
• Use a file compression program to extract the files.
If the driver files are packaged in a single executable file, you may be able to use a file compression tool such as WinZip or WinRAR to extract the contents of the driver package to a folder. The .inf file should be among the files that you extract.
• Use the Windows Compressed Folders feature to extract the files.
If you do not have the WinZip program or the WinRAR program, you may be able to extract the files by using the Windows Compressed Folders feature. To do this, change the file name extension from .exe to .zip. Then, use Windows Explorer to copy the files from the compressed folder.
• Extract the contents from the .cab file.
If there is no .inf file in the driver package, but there are one or more .cab files, you may be able to extract the contents of the .cab files.
Note This method is usually unsuccessful. Typically, these kinds of driver packages are created by using the InstallShield program. The InstallShield program uses a special .cab format that is not designed to be accessed by tools such as WinZip or WinRAR.
• Locate the files in the Temp folder.
If you still cannot access the installation files, try to locate extracted temporary files. Typically, files are extracted to a local Temp folder when you install a program. You may be able to view the contents of the driver package by examining the contents of the Temp folder. To do this, follow these steps:
1. Remove the contents of the Temp folder. By removing the contents of the Temp folder, you can more easily locate the temporary files that are created when you run the driver installation program. To remove the contents of the Temp folder, follow these steps:
a. Click Start and then click Computer.
b. Right-click the hard disk on which Windows Vista is installed, and then click Properties.
 In the Local Disk (DriveLetter) Properties dialog box, click the General tab, and then click Disk Cleanup.
 In the Disk Cleanup Options dialog box, click Files from all users on this computer.
 Under Files to delete, click to clear all the check boxes, click to select the Temporary files check box, and then click OK.
 When you are prompted to permanently delete the files, click Delete Files.
c. Use Windows Explorer to open the Temp folder. To do this, click Start
type %temp% in the Start Search box, and then press ENTER.
d. Start the driver installation program.
Note Some installation programs automatically delete the temporary files when the installation program exits. Therefore, leave the driver installation program running in the background.
e. Examine the contents of the Temp folder to locate the driver files.
Step 2: Manually install the driver
After you locate the .inf file for the driver that you want to install, manually install the new driver. To do this, follow these steps:
1. Click Start , right-click Computer, and then click Properties.
2. In the Tasks pane, click Device Manager.
3. In Device Manager, locate the device for which you want to install the driver.
Note To display hidden devices, click Show hidden devices on the View menu.
4. Right-click the device and then click Update Driver Software.
5. Click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer, and then click Have Disk.
6. In the Install from Disk dialog box, click Browse, locate an .inf file for the device driver that you want to install, and then click Open.
7. Follow the steps in the Update Driver Software DeviceName dialog box to update the driver.
on May 10, 2010 | Computers & Internet
Sir how can i connect my htc hero phon to pc
sir please install the htc cellphone pc suit to the computer.then connect the datacable from phone to the computer for transfering the files................
Jan 14, 2011 | HTC Hero Smartphone
I have the HTC PPC-6800. Cant read .jar & .jad files
Opera mini 5 is a tricky thing, I suggest trying the Opera Mobile 10 Beta, its much cleaner and installs with a simple .cab file that windows mobile understands.
http://my.opera.com/operamobile/blog/opera-mobile-10-beta-for-windows-mobile-phones
Sep 17, 2009 | HTC PPC-6800 Smartphone
MCI Error from SHOWMCIWND The Device Driver is not Ready
Mark
I also had same problem.
Go to
http://www.musiccoach.com/technical_support/errpages/mciset.htm
and install
http://www.musiccoach.com/technical_support/downloads/indeo32fix.zip
open, unzip, install "setup"
After this you can see all video.
Don't forget to set properties of file "charang guitar coach" : open with right click of mouse, open the tab "compatinbility" and set "compatibility mode to windows 98/ME or windows 95
Good playing guitar
Fausto Viegas
Jun 28, 2009 | Charanga GuitarCoach Full Version for PC
How to put games on imate jamin
Download the games that you want to play on your Pocket PC.
You can install it on your PPC using two ways:
  1. If the setup is '.exe', Connnect it to your PC thru active sync and double-click the setup file. You'll be guided thru the on-screen instructions.
  2. If it is a '.cab' file, transfer it directly to your PPC and click it to install directly.
Please rate if this solves your problem.
Jun 23, 2009 | i-mate Computers & Internet
Crc failed in Enterprise.ww\enterww.cab
Based on my experience there are many reasons that this issue may occur. I
suggest you try the following suggestions:
* Suggestion 1: Clear Temp folders
1. Click Start>Programs>Accessories>Disk Cleanup
2. Clear your Temporary Internet files and temp files.
3. Restart the PC.
4. Copy your Office 2007 files and folders to a local folder.
5. Double click on the Setup.exe to start the install process.
* Suggestion 2: Check the Environment Variables
I remember I have resolved some similar issues that the users report Office
2007 has failed to install. I have figured out this is caused by the wrong
configuration of the user variables. To check it, please follow the steps
below:
1. Right click on Computer, and choose Properties
2. In the Tasks list that appears on the left, click Advanced system
settings.
3. Click Advanced tab, click Environment Variables.
4. Under User variables for user name, check if TEMP is configured as the
following value: "%USERPROFILE%\AppData\Local\Temp"
* Suggestion 3: Install under Vista safe mode
Please try to install Office 2007 under Vista safe mode:
1. Restart Windows.
2. At the boot sequence, long press F8 key to invoke startup menu.
3. Choose Safe Mode with network connection on the menu and press Enter.
4. After Windows starts in this mode, install Office 2007 again and see the
result.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
Guitar hero 3 error intellaptopgaming.dll
Download Official GH3 1.3 patch. it will incluide the intelllaptotgaming.dll thing... that should work
Jan 02, 2009 | Computers & Internet
O2 xda 2 mini application installation
There can be three types of applications that you download from freeware sites:
  1. '.cab' files, that can be directly installed from your PPC
  2. '.exe' files, which are direct to be run applications that need no installation, just have to be placed in any folder and a shortcut has to be placed in the start-menu.
  3. '.exe' setup files. These files have to be opened in your PC while having your PPC connected thru Active Sync. This will install the application to your PPC thru your PC. These should be the kind of applications that you might be talking about for which you get such an error message "Not a valid PPC application!"
I think this should have solved your queries regarding PPC applications.
If this really solves your problem, Please Rate...
Aug 09, 2008 | Bosch WFMC 2100 Front Load Washer
Drivers and Active sync
Connect your MC50 to your machine. When XP see it as new hardware, double click this link below/or copy it to your browser address bar
http://www.cradlepoint.com/handheld/support/software_download.html
search for :MC50 setup for PS6U1UPE double click it. follow unscreen instruction. It should work just fine.
Jul 28, 2008 | Symbol MC50 Pocket PC
Symbol MC50 Pocket PC Logo
250 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
