Question about Samsung ML 2010 Laser Printer
I have a Samsung ML-2010 laser printer but whenever i try to print something it just makes that about to print sound and the light starts flashing as if it's about to print and then....nothing it just goes red again.
I have had this problem for some time now and the printer is fairly new what should i do?
This printer sucks, the paper jams every time. =)
Posted on Sep 03, 2008
  • 293 Answers
Is it connected directly too the computer or to a network?
What it sounds like is that you are having a spoiler problem, the computer is intialized but its not getting the info to print. Or it could be a printer malfunction, something mechanical isn't working right in the printer. If you've removed the ink cartridge and replaced it, it could be out of place or not seated right. Other components could be locked up. If the light goes red could you tell us what the error message is? And have you looked at your user guide for information on possible errors?
Posted on Sep 01, 2008
  • Kristoffer Martin Sep 17, 2008
    Well no, the printer doesn't ****. Each printer requires specific things to work. If a printer is getting jammed a lot it could be caused by the wrong weight paper. Unlike inkjet printer that can accept many types of paper, laser printers need a specific weight and sheen so that the magnetic field used to draw the laser guided ink will hold. If a wrong weight paper is used many problems can occur. Light coloring of the print, paper jams, and even damage to the print catridge and leads.
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Samsung ml 2010 in when start print tow led blinking
Think you may need to be a little clearer with your question to get any sensible answer. If you ar referring to the toner light flashing then you simply need to buy a new toner and replace it.
Oct 23, 2009 | Samsung ML 2010 Laser Printer
My samsung ML2010 printer has Error button flashing green
your printer is not inisilize properly. it is a logic card pls you can repaired it from printer vendor.
Sep 02, 2009 | Samsung ML 2010 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
I have a Samsung ML-2010 mono laser not printing
Yes, you can make a self print test from the printer even if the printer is not connected to the computer. This means that the unit is in good working condition. Possibly your printer doesn't communicate with your computer. try this, hit start key>control panel>fax and printers>select your printer>right click to properties>click ports tab>check if the port is matched to the port you are using.also, make sure it is your default printer.
Jul 08, 2009 | Samsung ML-2510 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
253 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
