Question about Creative Labs Zen Vision Digital Media Player
Firmware problem i tried to formate my Zen vision M 30GB, because the screen is bluryy i lost all my data & music, i cannot download new firmware itsay's docked but my pc does not dectect my mp3. How can i reverse the whole procedure
    Problem Solver:
  • 9 Answers
No take-backs. You can re-download the firmware. First you need to fix your player connection problem by going to Control Panel=>Uninstall Software and uninstall/downgrade WMP11 and WMP11 runtime. You should have WMP10 afterwards. Then go to Control Panel=>System=> go to the Devices tab and uninstall portable devices driver showing as the MTP Device. Restart. Connect your player via USB and it should be detected. Then go to Creative's website and get a firmware utility for your player by navigating the website. The update should happen automatically after you run the utility.
Posted on Aug 22, 2008
My creative zen vision M says FIRMWARE PROBLEM! HELP!
Hi you can try going to Creative's web site and downloading there Creative MP3 Player Recovery Tool software and what that does is update everything and most of the time it will fix what the problem . I would try that first.
I hope this helps
Mar 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
Stuck in recovery mode--would love to avoid buying a new mp3
I had the same problem as your and it stopped working yesterday. After search for helps and now it is working again after I reloaded the firmware. But unfortunately everything is gone. You have to reload your musics again. You can try this out: 1) go to creative labs website to download the "Recovery Tool". 2) at Recovery Mode of your zen there are options: Clean Up, Format All, Reload Firmware, and Reboot. Try out Clean Up first if it still not working then try to Format All. After that try the Reload Firmware. After you done the Reload Firmware. 3) Shut down your Zen and try to connect it to your computer. Now your Zen will automaticlly power On and computer will recognize it as a drive. 4) Open the Recovery Tool you have downloaded at creative labs website. This tool will detect your Zen and follow it's instructions: It works with my windows Vista. Well, it works for me, I think it will work for your too. Good Luck!
May God bless.
Jul 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Firmware problem for zen vision M
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Jun 24, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Touch firmware problem
This means both systems contain a bug, or cookie. If the firmware you accessed isn't applying itself to the device, this means the system itself has been corrupted. Double check with your system configuration properties on each device, and tell me whats going on from there.
Don't panic!
bananaboy101
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
Cannot reload firmware
I had the Exact same problem and no one had a good solution, i only found one that finally worked after spending 4 freakin hours tryin to fix it. anyway here is the solution.
you need to use a computer that has Windows XP, then if the computer is running any version of Windows media player other than 10, roll back or upgrade to Media player 10. restart the computer.
Now, you need to download and run http://www.delldjsite.com/forums/attachment.php?attachmentid=462 honestly i have no idea what it does. my guess is it reinstalles the USB ports but thats only a guess. but i was so frusterated by the time i found this solution that i was willing to try anything. so download this file, unpack it and run it. then it will ask you to restart. when your computer is restarted run the new firmware file ( i used 1.62.2.0) and it works.
Why? i have no idea, but it i was pumped. the origional site i got this solution from is http://www.anythingbutipod.com/forum/showthread.php?t=18864
Jan 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs 30GB Zen Vision:M
To put songs on your creative, just use the software that came on the cd. If you don
Jul 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen Vision Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
