Question about Fisher Paykel EcoSmart GWL15
Fisher and Paykel Smartdrive MW051
The touchpads on the fascia of the above machine have become worn and the Start "button" no longer works. There is power to the unit and all of the display lights work. Is it likely that the display contoller is at fault i.e that the button on the PCB has become damaged, or should I look further afield? regards, Malcolm
  • 46 Answers
Hi
if the decal on the panel is damaged then it can let moisture ,dust and things into the switch underneath and it will fail ,i have repaired /replaced these switches but it is a tecs job otherwise you will need a new module
cheers grant
Posted on Oct 22, 2008
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel 5.0 smartdrive washine machine
No reset button in these machines.
Check your lid switch & display board for corrosion.
Apr 20, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
May 30, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel smartdrive lets water in in spurts then stops
might be an overload. remove some clothes and retry. I have the manual here on my site:
Use the sire search to find it
http://sites.google.com/site/sublimeappliancerepair/Home
Aug 31, 2009 | Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Hall Sensor Fisher & Paykel mw051
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Here is a good parts discounter we use. If in stock they ship quick .
Please give me a good rating before you sign off fixya.com
Aug 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
80 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
