Question about Kenmore Elite 45986 Front Load Washer
Stinky clothes my clothes stink from the washer. Then my clothes smell burnt from the dryer. Both machines make my clothes stink
  • 2 more comments
  • mccarty Aug 18, 2008
    I have soap scum releasing during my wash cycle leaving my cloths dirty. I have run the wash cycle with javax. I have tried C.L.R. and I have tried vinigar to clean the machine. I have taken hot water with javax and cleaned around the black rubber around the door and used a toothbrush to get in and scrub the gunk away. Then when I wash cloths there it is again.
    How can I clean this scum from my washer. It is a front load Kenmore.
  • meg8 Sep 01, 2008
    I have the same problem. It smells to me like the clothes aren't getting clean... I'll try cleaning around the seal but I wonder if the soap isn't reaching the laundry tub somehow? Is this possible, too?
  • Anonymous Sep 02, 2008
    I started to notice the smell, especially on my bath towels after using the washer for approx 1 year. I have tried cleaning the rubber seal around the door with everything and washed clothes with baking soda, bleach, hot water, and every laundry detergent made. nothing helps and I
    am very dissatisfied with this washer. It was too expensive to have this type of problem.
  • cakegirl Sep 05, 2008
    yes, I have the same problem too!! It is the worst smell!
    I can smell it all day long on my clothes!! It smell like burnt dry dust!
    Everything stinks!! I cant even stand to dry off with my bath towels it is so bad.
  • 876 Answers
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Posted on Aug 18, 2008
SOURCE:
KITCHENAID W10311123B STINKS
use the following product. God bless you
Affresh
HE Washer Cleaner - Recommended by Maytag and Whirlpool
Odor Remover and Smell Blocker .Oxigenated cleaning action lifts away the Stinky,smell odors in your HE washing Machine.
Jul 29, 2013 | Washing Machines
After I dry my clothes, I smell this dead animal smell. Thought it might be a dead animal, but could it be the ring around the drum that is burnt? My clothes now dry smell stinky. We took it all apart...
thats the mold and mildew on the bellow that you are smelling. thoroughly clean the bellow. i also suggest that you purchase a tablet called affresh. this will help to remove that smell. if your machine does not have a self clean cycle then just put the tablet in and do a regular wash. if you machine has a clean cycle, just put tablet in and set on clean cycle. I also recommend that after each load you thoroughly wipe off the bellow and leave the door open for about 30 minutes so that machine can air out.
Feb 05, 2011 | Dryers
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
Washing machine stinks
do the clothes stink too? or just the washer? if you have a crawl space check the washer drain it could be draining under the house...and vapors coming up through line......
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 | Dryers
STINKY CLOTHES
detergent ??? yo are using a HE detergent correct??? foul odors can be attributed to over soaping in clothes this may be a real problem if not and even then you ll need to dramatically cut down on the amount of soap you use.. oneway to determine the "oversoaping " is to take a recently washed sock from the drawer and place it in a cup of water , with oyur fingers agitate the sock up and down in the cup and see of suds form if theres your problem.. this was posted no to question yor laundering techniques, or to be a smarta**, but oyou didnt mention you detergent so just wanted to rule this out.
Mar 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Towels smell oily and moldy--really stink
Don't use fabric softener. I had the same problem and read somewhere to stop using the fabric softeners. I don't know why but after about two cycles (they smelled really bad) it worked! I always used fabric softeners with out a problem but one day I just started getting REALLY smelly towels. I always take my wet wash out as soon as the cycle ends and dry it completely so I was surprised when they smalled so bad. Give it a try.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Stinky clothes
I have the same problem - the clothes smell like they have been left in there for a week - stale or moldy.
It only happens with dark clothes - I have started adding color safe bleach or oxy clean and sometimes a tiny spash of bleach - it seems to have solved it.
Sep 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
448 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
