Question about Sony Playstation 3 (PS3) Console
Internet Connection I had my ps3 wired connect with an ethernet cable to a router, and Im trying to switch it to wireless on campus. But it will not give me the option to switch to wireless, it cannot find an ip address either. I need help how to do the wireless, it will not even give the option.
  • sweeeet_gurl May 11, 2010
    how far is your ps3 from your router? its could be out of range
    and are you sure your router is wireless? its should have an antenna.
    On the ps3 you can only have 1 active connection, so you have to specifiacly enable 'wired' or 'wireless' connection. if you have wired still selected it might not find any connections.
    Sergeant:
    Champion:
  • 236 Answers
On the X-Cross Media Bar, (the menu that comes up when you turn on the PS3) under "settings", go to "Network Settings".
then go to "Internet Connection Settings". select "yes".
go to "custom", "Wireless", "Scan".
If your network is not listed, move your PS3 closer to the Wireless Access point.
Select your Network and enter your password (if it needs one).
select "automatic" for everything.
select "Test Connection".
the "Obtain IP Adress" and "Internet Connection" should say "Succeeded".
If not, contact your system or network administrator or a teacher that knows a lot about computers.
Posted on Aug 18, 2008
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Can i hook up my ps3 to a wireless laptop with an ethernet cable?
you can for the 360 go to ur network then i think properties then share network(on pc) its on youtube im not sure about ps3 i have wireless
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
How can i get my 60 gig ps3 to go online with wireless connection
the only way you can connect a PS3 to the internet is either though an Ethernet cable what comes out of your router
Or By Wireless
Dec 17, 2008 | Sony PlayStation® 3 (60 GB) Console
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
