Question about Pentax Optio S4 Digital Camera
Optio s4 cracked LCD
I have a newer Optio s4 with a cracked lcd screen and I have an older Optio s4 with an OK lcd screen. How much would it cost to move the OK lcd screen from the older Optio s4 to the newer Optio s4?
Or can I do it myself - I opened up the older one and the lcd screen had two wires soldered to it and a ribbon attached but without an obvious ribbon connector - so it doesn't look as if it can be easily removed.
Thanks,
Michael
[email protected]
6ya staff
SOURCE:
Anonymous
SOURCE: Pentax Optio A10 lcd replacement
Re PENTAX OPTIO A10 LCD Replacement
I wish Mike Brunner would advise us where we can get a replacement LCD for $40, was it from a used camera?. A new one  from PENTAX   Part Number 76650-0500 Tel 1 800 877 0155  Is just under $60 plus $8 shipping in the USA but is currently out of stock. There is also a San Diego company with limited stock (5) that wants about $70.
 Removal of the LCD is relatively straight forward.  First remove the battery and the card. Then unscrew some very minute philips screws and carfully remove the back cover. Separate the two halves of the cover with a thumbnail to unhook a snap connection after the screws have been removed.
It's best not to remove the front cover so as to avoid damage or contamination of unrelated areas.
To remove the LCD look for the retaining snaps and gently pry the left side ( camera facing forward and upright) back and lift the
left side of LCD up and unhook the right side.
The LCD will now still be attached by the multi wire strap and a minute two wire connector. Using tweezers on the plug and not the wires gently disconnect the two wire connector. The multi wire strap with about 25 miniscule gold connectors is held down on the mating contacts with a clear sticky tape. I was able to pull mine loose before I saw the sticky tape.
To reinstall the replacement LCD a very good magnification of the 25 or so contacts may be required to correctly line up all the mating contacts on the back of the camera as there is no apparent mechanical means to correctly align this.
There is no soldering required or practical at his connection.
Use some clear sticky tape to hold it in position.After reconnecting the 2 wire plug the right way up and when the LCD is folded over back into position and snapped down into to the retension snaps,this should also apply gentle presure to the 25 pin connector. Adding a very thin layer of non conductive material over the 25 pin connector before snapping the LCD back might be helpfull in the longterm retension but too much compression will may fail the new LCD. ( Well that is what I'm going to do when I get my LCD) ( I may also put the battery and card back in and switch it on before replacing the rear cover taking care not to get an electrical shock through some accidental discharge, so don't do as I say unless you know what you are doing)
 Re assembling the rest should be straight forward. Then test the result.
 Note: The camera buff who encouraged me to do my own repair has added an extra layer of clear plastic over the exterior cover of the LCD to better protect it. It is also advisable to have a hard case or reinforce a small soft case with a used credit card to protect the LCD, so as not to have to repeat this again.
Good Luck. From Santa Cruzer
Posted on Oct 16, 2007
Anonymous
SOURCE: Where do I get the file:fwdc110p.bin ?
http://www.badongo.com/file/707791
You can download the file from the above site - I think this might be the exact reference. Then go to the most recent entry on this site for the secret menu process http://forums.steves-digicams.com/forums/view_topic.php?id=82905&forum_id=24&highlight=A90
Rember to place it on your card at the same level as the DCIM file, not inside it like I did at first. It came zipped so you will need to use Winzip. I will now try and polish this a bit on that site while it is still fresh in my mind.
Posted on Feb 01, 2008
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: A90 error Optio S4
Gerrit
So is jou probleem uitgesorteer ?
Posted on Apr 17, 2008
Ty Price
  • 11967 Answers
SOURCE: Pentax Optio MX4 won't read my new SDHC 4gb
Does the camera work with any other card? Was the card formatted in the camera? Some cards from some manufacturers just don't work in some cameras.
Posted on Sep 13, 2009
Anonymous
  • 125 Answers
SOURCE: cracked lcd pentax optio a20
I'm sending you link to see how to do it. http://www.youtube.com/watch?v=U0DSO_EyX9g.
Good luck.
Could you please tell me if you can sell to me the small part (plastic that keeps the battery and make click when you take the battery out from your second unused camera?
Posted on Sep 22, 2009
Lcd screen of Pentax camera damaged, I am located at Indore, MP
Perhaps you just try to contact Pentax for this? But I think if you could buy a LCD screen, it will cost you more than a brand new camera, with better specs than your Optio M20.
So perhaps you start saving for a new camera?
May 04, 2014 | Pentax Optio M20 7MP Digital Camera with...
Instructions for replacing lcd screen optio m40
cheaper to buy a new camera, I got mine for 100 bucks from Buy.com, you wont be able to replace the lcd screen without sending it in
Jun 29, 2010 | Pentax Optio M40 Digital Camera
Cracked lcd pentax optio a20
someware you can detach the cable
Apr 11, 2009 | Pentax Optio S4 Digital Camera
Cracked lcd optio a10
It is tricky to open this case without breaking it. I repair these for $55.00 e-bay store camerashyanna
Jan 17, 2009 | Pentax Optio A10 Digital Camera
PENTAX OPTIO A30 BROKEN LCD
I've seen LCDs forA30 are sold via eBay.
In youtube there's a video of replacing the LCD in other Optio model.
I have the problem and I'm going to try it by myself. I'll let you know if it worked.
Jan 08, 2008 | Pentax Optio A30 Digital Camera
Pentax optio s6
perhaps mazzachris would be interested in unloading his/her E10 LCD to me?  My E10 LCD is cracked.
Sep 03, 2007 | Pentax Optio S6 Digital Camera
Optio s4 - help needed
You are probably in play mode and not in camera mode. Switch the camera back to camera mode (move the witch so its in the camera position- you will see a small camera icon) in order to take pictures.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
S4 LCd problem
my screen wont let me do anything the screen comes up as card locked
Pentax Optio S4 Digital Camera Logo
16 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
