Question about Kenmore 44042 Front Load Washer
Water filling issue with mty kenmore 417.44052400
The soap dispencer door was opened during cycle and the water will no longer fill. Is there a sensor for the soap door that may have broken.
  • Anonymous Mar 31, 2014
    Dispencer not removing soap
Yes on the dispenser door there is a magnetic switch that looks like a thin black cylinder similar to a short pen . About 1 1/12 long. It may have been dislodged. Make sure the dispenser door is closing all the way.
Posted on Feb 05, 2009
My dishwasher detergent dispenser still has the detergent in it when the dishwasher is complete with the cycles. I hear it fill and go through the process but dishes are dirty and soap isn't gone
Sounds like it is not getting enough water ( up to element) The water has to be 130 F to work well. Is the water draining out after fill . Just open during cycle and check these things
Nov 22, 2010 | Kenmore Dishwashers
After the cycle ends there is still soap in the soap dispenser. Why? What can I do?
make sure the flap opens and closes freely. If not clean with limescale remover. If it is ok. Your dishwasher may not be filling all the way. Open the door mid cycle and check the water level.
Mar 15, 2010 | Kenmore Dishwashers
Kenmore Dishwasher doesn't rinse? It sounds to be working fine, however, at end of cycle, dishes are still dirty, and the front door on the inside is still dirty. Obviously there is a problem here...
try opening the dishwasher during the wash cycle stop it and open it if water is in the bottom it is filling whn you open do 1 or 2 times to check to see if spry arms are spinning if they are check to see if soap dispenser is working also use dishwasher cleaner once a month available wherever tou shop for groceries in the dish soap dept. directions are on label
Dec 15, 2009 | Kenmore Dishwashers
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Detergent Fill Dispenser
It may be gummed up inside with old detergent that has caked on . Try rinsing out the despencer until it opens and closes easy. DFD
Apr 22, 2009 | Dishwashers
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 587
I think you are right. That would be the most obvious answer. Some motors are warrantied for 2 years or longer.
Nov 02, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 44042 Front Load Washer Logo
180 people viewed this question
Sal De
fordexpert
Robert Rankin
