Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Desktop works (direct to router), laptops cannot connect
Internet worked fine this morning. Went to check mail this afternoon on wireless laptops & found that there was no connection. Did the normal resetting of router but still cannot connect on laptops. Internet on desktop works fine, hence this post.
Also tried resetting the network completely but to no avail. Network name shows up in list & is detected, sometimes will ask for network key, will attempt to connect but then we get message/Windows bubble saying it cannot connect to the network. My HP Vista Ultimate laptop says it does not receive a return signal from the router, and our XP Toshiba says that it cannot connect to the network, or "there might be interference between this computer & the network access point or the network is refusing access to this computer". It offers the option to repair but then cannot reset the IP address.
We've exhausted all of our options & are completely lost. I need the wireless laptop for business & need things up & running again ASAP. Any assistance will be greatly appreciated. Thank you!
  • Anonymous Mar 23, 2009
    where do yu check the wireless settings for the router and the wireless settings for the computer?
  • EcoYoda Apr 03, 2009
    Outbound access to the INTERNET does not work most of the time. ISP is Verizon FIOS. Internally between three desktops and one laptoop works fine.
    I spent over an hour on the phone with Verizon and then Netgear last night to no avail. WPN is supposed to be PPPoE, but insists on having a fixed IP address.
Thanks for the suggestion. Oddly enough, after 2-3 days, the laptops were suddenly able to connect again. Strange.
Posted on Aug 24, 2008
  • 89 Answers
First of all make sure that the wireless settings of the router match the settings of your wireless computer.
make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
Wired connection don't work, but wireless do.
You can use your USB connection on your Cable moden for your Desktop PC and then bridge to another through that computer's Ethernet connection to another's Like your Laptop. you can go into your network center on your desktop and go to your connection's status, then go to the sharing tab and check "Allow other computers to access this connection to the internet" or such as.Thsi can work for you Xbox 360 as well, it worked for me
May 06, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Connecting desktop and laptop to a wireless router
I have the same problem. Startign this morning, when I connect modem directly to desktop, it works. But when I connect modem to this router and then connect to desktop, nothings works.
again - if connect modem back to desktop directly, then it works!.
what is the issue.....? not able to figure it out.
I did reset, change router IP etc etc everything nothing resolves the core issue!
Jul 19, 2008 | Linksys Wireless-G Broadband Router
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
245 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
