You have to perform a hard reset, which means you will lose all of your personal data. Just had the same problem with mine and hard reset it a few minutes ago. hold and Vol Up and Vol Down as you hit the power on. keep holding the volume buttons until you get a diagnostic screen. Hit Vol Down, and your phone will be reset.
Hey, Call your service provider to ask your HTC 7 Surround Network Unlock Code. when you change your current network provider you must need to Unlock your HTC 7 Surround first. after unlocking you can use your HTC 7 Surround to any network.but network provider take time to give your imei unlock code. second option is, you can buy your HTC 7 Surround Imei Unlock Code from third party . this is safe way to Unlock your HTC 7 Surround. they will charge little amount but they give your HTC 7 Surround Imei unlock code immediately. i hope this information is help you.
i have the same problem, but mine freezes for a few seconds after unlocking. None of the buttons work and then randomly itll be fine and everything will work. Its like a 3-4 second delay after I unlock it. Also, when im using the phone, the brightness level changes every few seconds, from dim to bright, dim to bright, also really annoying. I'll let ya know if I find out anything, good luck
i did some research and it appears your problem is related to activsync the best solution i found was to delete the partnership in activ sync and make a new partnership with your phone. this is not just for your type of phone it seems to happen with wm phones alot. have you install a program called MemMaid if you have it may have caused the problem apparently.
I had the same problem whenever i tried to type... i fixed it by going into settings then input then word completion and then i cleared the stored entries ... if that doesn't work u can try un-checking the suggest words when entering text box ... Hope this helps
